Stroker Running Rough (videos)
  • NC325iC
    • Mar 2004
    • 6565
    spark plugs new, just swapped the injectors for 19#ers, there are normal amounts of smoke from the exhaust.
    new video after the injector swap and retune for diff injectors, problem is diminished but still there.
    • scabzzzz
      Estado de mierda de encargo
      • 6871
      Damn dude. Your car sounds like a turbo Cummins diesel. Blub blub blub WADD blub blub. :)
        • 34844
        I dont think your crank sensor is an issue. What happens if you run all stock stuff?
        • N2MYE30
          • Oct 2007
          • 5536
          Well, im at least glad the injectors work. Did you check out the valvetrain yet?
          COTM
          • NC325iC
            • Mar 2004
            • 6565
            running all stock stuff I haven't tried yet. I'd have to pull it off my other car. Haven't pulled the VC yet, I'll do that next I guess.
            • NC325iC
              • Mar 2004
              • 6565
              so i thought about it and i cant really run all the stock stuff without redoing some wiring you have to do for the MAF.
              but i did run the stock computer with the MAF unhooked, and that was inconclusive.
              switched the warchip over from my 525 ECU to my 173 ECU and no difference there.
              what the hell is causing this?
              scratch that, i just started it up again with the 173 and it seems to be running alright, might go take it for a quick spin around the neighborhood
              • NC325iC
                • Mar 2004
                • 6565
                very peculiar, the 525 with a stock chip runs fine in the stock car (convertible)
                perhaps the war chip doesnt play nicely with the 525 ecu?
                • matt0300
                  • 549
                  sounds like my car, i pulled the vc found a broke rocker arm :(
