I did a quick search on this and could not find a solution for this issue. I have a 1985 BMW 325e.
I have oil leaking from what appears to be the vent hose into the throttle body which is running down the air intake into the air filter and assume it is also running into the engine. I have never seen this before, usually the hose vents much higher into the air cleaner and assume it could cause future issues if not something already.
If anyone has any insight on how to fix thisI would appreciate it, I looked for a PCV valve but couldn't find any, looks like it just vents directly.
