Hmmmm OK. 2 identical sensors installed in different locations on the same engine reading about 10 degrees different is enough proof for me. I couldn't find any information about the pressure senders having to be 45 degrees of vertical but I thought I'd mention it. Jim Powell didn't tell me anything but he can verify this since I know he's experienced the same issues with VDO's on his E36 well before DDM was around. He mentions it in one of his write ups.
For those of you with oil temp and pressure gauges...
Hmmmm OK. 2 identical sensors installed in different locations on the same engine reading about 10 degrees different is enough proof for me. I couldn't find any information about the pressure senders having to be 45 degrees of vertical but I thought I'd mention it. Jim Powell didn't tell me anything but he can verify this since I know he's experienced the same issues with VDO's on his E36 well before DDM was around. He mentions it in one of his write ups."I'd probably take the E30 M3 in this case just because I love that little car, and how tanky that inline 6 is." - thecj
88 M3 - LACHSSILBER/SCHWARZE
I'll say it again, you can toss out the window anything anyone from DDm tells you.
And unless you install a sensor into both the pan and then filter/head at the same time and take readings and data log them, it's not "proven" - it's what someone experienced. I'm not saying it's not the case...it's just not very exact now is it?Originally posted by Matt-Bhey does anyone know anyone who gets upset and makes electronics?Comment
And unless you install a sensor into both the pan and then filter/head at the same time and take readings and data log them, it's not "proven" - it's what someone experienced. I'm not saying it's not the case...it's just not very exact now is it?"I'd probably take the E30 M3 in this case just because I love that little car, and how tanky that inline 6 is." - thecj
To bring an old thread back to life.
I put oil temp and press gauges in my jetta this past weekend. I used one of the sandwich adapters. Only issue I had with it was that it didn't ground the senders good enough, maybe its due to the anodizing. Either way I put eye connectors below the senders (not in the pic) and properly grounded them.
My oil runs around 210. I've seen it go as high as 230 when I had it floored going up a steep hill.ส็็็็็็็็็็็็็็็็็็็็็็็็็Originally posted by blunttechI need you to exfoliate my ballsack
