Hey guys, I have been having an idle problem the whole time I've owned the car.
link: http://www.e30tech.com/forum/showthread.php?t=104481
My eta still has idling issues..
On start-up it run's up to like 3k on the tach (it only goes up to like 2200-2500 on the first start in the morning when my oils still cold n thick but every other start throughout the day hits like 3k)
after 4 or 5 seconds it drops down to 1k and then just surges between 1k-2.2k..
I have looked for a vacuum leak, and given the fact that it runs very rich, leads me to believe that it is not a vacuum leak..
I have changed my Idle Control Valve, the Idle Control Module, AFM, and cold start valve.
edit:
I went ahead and cleaned my ICV(even though I replaced it with a known working one), cause it had a lot of carbon build-up inside of it.. That didn't make a difference as far as the idling issue though, but it's sure as hell cleaned up now, the inside piece moves as it should
edit:
Well no dice after replacing the DME. I'm stumped and it's really getting annoying.. Any other ideas?
However on a side note, I ran about a half a can of Seafoam through the vacuum line that is coming out of the intake mani and the occasional laggyness is gone, but my idling issue is still there..
edit:
changed the TPS and no go on that one either..
Anyhelp would be greatly appreciated,
Rob
edit:
edit:
edit:
Rob
