Car turning off while goin down the road.
    I just rebuilt my 88 325i from the head up and it has a check engine light code for afm. I was wondering if this could be the reason for the car shuttin off as it goes down the road? I need a new afm and would like a new ecu. So if you can help me out I would greatly appreciate it. Thanks.
    Ashton.
    how loud is your fuel pump?
    double check your afm with known good afm. swap airboxes from a friends e30.
    AWD > RWD
      My fuel pump is loud. Is that bad?
          A loud pump is one that is having to work too hard or one that is dying.
            Crank positioning sensors will do this all day long. Is it cleanly shutting off? or is it stumbling before shutting off?
              Its cleanly shutting off.
                i'd replace the pump. its $150 new on amazon and its something that you'd want to replace anyway if you are planning on keeping the car for awhile.
                AWD > RWD
                  its the crank sensor. 20 bux will fix that
                  Originally posted by E30_(1st Musk)_
                  HONDA IS WHERE EVERY TREND DIES! .
                  24v swap Oil Pan..F/S
                    A bad CPS is an obvious suspect. But there are other possibilities. Start with the a new CPS and see what happens.
                      I would FIRST bypass the main relay, it is easily the most common failure for what you are describing.
                      Your fuel pump being noisy means it has more draw, that means your main relay is working even harder.
                      Closing SOON!
                      Thanks for 10 years of fun!
                        What do I get for $20? Lol
                          How do you bypass the main relay? Im a noob.
                            U know I had a very similar problem! It turns out it was the battery. It was over two yr old , and wasn't holding charge , and the clamps were loose. It never hurts to check
                              you rebuilt the engine, but you dont know what a cps is or how to bypass a relay?
                              AWD > RWD
