could failed motor mounts cause this?
  • McGyver
    • 4618
    The fan blade cut through the hose and I got to piss coolant all over the Kroger parking lot. now its patched with zip ties and gorilla tape. Its also ziptied back from the fan.
  • billybobjoseph
    • 213
    The hose is attached to the motor on both ends as is the water pump and fan. They should all move together. If the fan blades caused that ( I'm guessing that's the case ) for some reason your fan is moving eccentricly or is lose.
    • ak-
      • 12422
      ^^ Yea, basically if a mount failed, the fan would hit your radiator first.
      Your car would be vibrating too from the slight misaligned drive-shaft most likely as well if that was the case.
      1991 325iS turbo
      • McGyver
        • 4618
        thats a good point. i hadnt thought about everything being connected. So even if the motor mounts were bad, everything would shift together. i guess that guy was wrong.
        maybe my hose wasnt back far enough or was tool long on that part?
          • 37829
          There's a factory plastic clamp that holds that hose to the front engine lift bracket. If that was missing it could let the hose go forward and hit the fan. Pretty common problem and nobody seems to know about the factory clip.
          Classic BMW Specialists
          Grover Beach, CA
          www.BimmerHeads.com
          • billybobjoseph
            • 213
            That's possible, the hose has a prefitted shape and goes from the top there over the head behind the cover for the distributor and then down to the water pump. Maybe it's not connected to the correct port at the top? Should be the middle of the three ports. Or maybe someone put the wrong hose on the wrong spot after having removed them.
            • McGyver
              • 4618
              nah, i know its on right in the right spot cuz i did it, i just didnt know about the clamp that keeps it in place. I guess thats why the PO had cut part of the end off of the hose the car came with...
              • billybobjoseph
                • 213
                Darn those PO's.
                • McGyver
                  • 4618
                  well as long as the tape and zip-ties hold it together while i take this girl out tonight i'll be happy. theirs nothing better than your taking a crap on you right after she says that its a cool old car.
                    Failed motor mounts won't cause that, by a bad fan clutch or bad water pump can. With the belt off, see if you can move the fan around.
                    • Plastic Emperor
                      • 34
                      Winner!
                      I may have an extra if you want it
                      • mohamadr89
                        • 282
                        both of my motor mounts broke and i didnt even know it. i was driving the car for a while and the only problem i had was every time i hit the brakes the fan hit the radiator and made a loud ass noise. but i dont think the fan will hit the belt...
                        mtech 2 325ic
                        http://www.r3vlimited.com/board/pict...pictureid=7968
                        check out my donut vid
                        http://www.youtube.com/watch?v=Tw0paUP1FEQ
                        • McGyver
                          • 4618
                          Originally posted by Plastic Emperor
                          Winner!
                          dude, i would be all over that if you really do have one. (im not much for the zip-tie look). ima gonna pm u.
                            • 37829
                            They're like $4 new I think. :)
                            Grover Beach, CA
                            www.BimmerHeads.com
                            • sandlock
                              • 946
                              anyone got a p/n? is it #3?
                              ReverseOTL.
                              NewParts4sale.
                              PartsWanted.
