Getting the fan off the water pump...
  • Andy348
    • Sep 2009
    • 688
    I got tired of trying to take the clutch fan off the water pump, so I just pulled the entire pump off. Now that I'm calm, I'd like to take another whack at this. I've currently got it sitting like this, in a vice:
    And I don't currently have a 32mm bicycle wrench, so I'm using a large pair of vice grips and a fairly BFH. I've given it a couple of hits, and it seems like the wrench is just slipping off.
    So I'm going to find a 32mm wrench somewhere, but does anyone have any tips/ideas?
    TIA
  • JTapper
    • Sep 2009
    • 847
    Get a 32mm wrench.
    Turbo Cabrio project: http://eurowerks.org/showthread.php?t=19677
    • billybobjoseph
      • 213
      1 1/4 inch wrench will fit nicely and remember it's reverse thread.
      • bimmerteck
        • 762
        qft.
        • McGyver
          • 4636
          if you leave the belts and the pump on the car the tension from the belt usually holds the fan pulley tight so you can take the fan off. too bad you took everything off...
          • redhatpat
            • Aug 2005
            • 656
            +2
            • gp.plus
              • 416
              You can buy the wrench from any bicycle shop for < $10
              • Andy348
                • Sep 2009
                • 688
                Just went to 3 bike shops, none of which had one. They wouldn't lend them either.
                Oh well, I'll keep asking around.
                • slammin.e28
                  שמע ישראל
                  • 12054
                  Maybe bring the WP to them? If you're really desperate.
                  • urbancynic
                    • Dec 2008
                    • 384
                    Go to Sears and pick up a 32 mm wrench. They usually carry them, and it fits in there just right.
                    • groundpilots
                      • Oct 2009
                      • 14
                      go to bav auto and buy the two tools you need, one holds the waterpump pulley in place, aswell as a wrench to get the bolt off, took like 5 mins to get mine off
                      • bimmer630
                        • 1230
                        Or use a air hammer on the flat of the nut
                        • quikveedb2
                          • Sep 2007
                          • 2258
                          The right tools for the job go a long way. A bike shop could get you a 32mm wrench in a couple days if you had planned ahead, and I've never encountered a shop that lends tools. I'd bring it to them & let them know it's reverse threaded at this point, and maybe just order the tool while you're there.
                          You know why you're drinking that Pabst? No its probably not because it was the first beer you grabbed. It's because you're a winner.
                          • hotballs
                            • 1155
                            A torch and a lot of PB Blaster worked for me. Either way you have to immobilize the pulley one way or another. Either with tension, a homemade tool or something. I had to get creative.
                            • digger
                              • Nov 2005
                              • 6206
                              i've been using a flat piece of steel with a notch cut in it to act as a spanner for more than 10 years never had a problem.
