hi idle grrrrr
  • long tall eta
    • Jul 2010
    • 1536
    Originally posted by jlevie
    The booster itsefl can leak.
    Since several tiny leaks can add up to a sizeable leak, don't assume that you don't have leaks in parts that look to be in good condition.
    will a smoke test detect leeks in the brake system?
    • 325ix
      • Aug 2009
      • 7783
      I was curious about that too.
      • Pantless Spency
        It's McRib time!!!
        • Feb 2011
        • 7283
        same thing was happening with my eta and i replaced the intake boot as it was taped up from being ruined - didnt fix the problem so i throttle body cleaned the ICV and it made things better for about a month then started acting up again, so i went to pick n pull and pocketed an ICV and put it on my car and now it idles great just around 900-1000
        • long tall eta
          • Jul 2010
          • 1536
          will a performence chip lead to high o2 readings. should i put the stock chip back in before i retest?
          • long tall eta
            • Jul 2010
            • 1536
            so, i had the smoke test done today. small leak where the hose from the tb to the vc enters the vc. replaced it. idle dropped some. down to 1000 but still not the 800 that she was before. o sensor next on the list.
            • PNWDan
              • Feb 2011
              • 1326
              I didnt see replacing the TPS on your list. Did you? If not that is probably the cause. The TPS controls the ICV and so the ICV cant do its job if the TPS isnt doing what it should.
              1987 Alpinweiß 325is
              Like the PNW E30 Local Crew Facebook page
              • long tall eta
                • Jul 2010
                • 1536
                yes. i replaced the tps. so now what? oxegen sensor??
                • 325ix
                  • Aug 2009
                  • 7783
                  Did you replace the icv?
                  Well, I still have a CEL. It says it is O2 related. I think it is still a vacuum leak.
                  It is not:
                  -exhaust leak before O2 sensor
                  -O2 sensor
                  -inatake gaskets
                  -t-body gasket
                  -t-body boot
                  -all vacuum lines look good
                  -breather hose is new
                  What else could it be?
                  Gas cap
                  dip stick
                  brake booster
                  charcol canister
                  How can you check these things?
                  The CEL only comes on when idleing. It stays on when I drive though. Could the tps, ICV or idle setting be causing a CEL? It idles right around where it should now.
