Fuel injectors 200cc on stock m20b25
  • tommye
    • Jun 2011
    • 11
    My stock fuel injectors are a bit leaky,
    happen to have some reconditioned mustang injectors laying around.
    If i put in these 200cc injectors and change the FPR to a 2.5bar one,
    will that work?
    You could use the Mustang injectors, but you'd need a chip tuned for that flow rate. Even then, with that big of a jump in flow, idle might be a bit iffy
    • tommye
      • Jun 2011
      • 11
      Ok, but the mustang ones flows 200cc at 3bars,
      shouldnt they flow a bit closer to the original's at 2.5bars?
        • 34847
        why would you want to decrease your fuel pressure and have the same flow rate? atomization and efficiency will suffer, the MPG/OBC won't work anymore, among other problems.
        • tommye
          • Jun 2011
          • 11
          So, where to get a chip that fit these injectors?
          • digger
            • Nov 2005
            • 6215
            sell your reco'd mustangs and get some reco'd ones that flow closer to stock
