Shrick 288 Cam. yay or nay?
  • MR.LUGO
    • 905
    Hey guys, i know this topic is on here but just want some more opinions. Just wondering if this upgrade is really worth it. Right now i have:
    -stock m20
    -19lb injectors
    -Longtube headers, no cat,straight pipe to Magnaflow 14815
    -Chip
    -Miller MAF
    So i'm not sure which cam would be best, i know the 288 will require upgraded valve springs which will add another 300 bucks. And for the most part, the car is my daily, haven't tracked her yet but if i do it won't be very often.
    Any input is apreeshed.
    Got all da Alpine bitches mad cuz my main bitch Calypso.
  • Gruelius
    • Oct 2009
    • 298
    also need to check valve/piston clearance and probably grind out the reliefs a bit.
    RIP 84 323i coupe 5spd w/ 14psi
    89' 318i
    • Danny
      • 14216
      Will not be worth it on an otherwise stock motor.
      • MR.LUGO
        • 905
        Yeahh, too much moniezz. also nice calypso you got now danny
        • BMC227
          • Apr 2011
          • 448
          -stock m20
          -19lb injectors
          -Chip
          -Miller MAF
          I say do it, valve cut outs require a little grinding but apart from that everything else is fine. Don't bother with valve springs, they're a waste of money. The standard springs work just fine and you won't be revving past 7k. My Alpina has a 293 cam with standard springs and revs to 7200 and it loves it! the engine has been going for 10 years now since re-build and i've never had a valve spring problem.
          They call me the frog
          - E30 Alpina C2 2.7
          - E30 Alpina C2 2.5
          - E28 M 528I 3.5 (300HP)
          - E36 M3 S50 3.2 (Euro)
          • der affe
            Technical
            • Dec 2005
            • 8452
            you are better off doing a 2.7i swap or better yet, an m52 crank, eta rods and i pistons along with your 885 head as a better return for your money invested with a true budget stroker and resulting in a 2.8 lt motor.
            if you need to grind the valve relief pockets to run the cam, you are part of the way there to doing a rebuild anyway.
            you can also run a big cam later and at that point, you will have more motor to make use of the big cam.
            stock springs and good rockers will work just fine with that cam.
            it is not a cam tracking issue as much as a valve float issues when exceeding 7400 rpm.
            the ramps are not super fast on the schrick cams, necessitating the stiffer springs.
              • 37833
              Definitely too big of a cam.
              Grover Beach, California
              BimmerHeads.com
              • digger
                • Nov 2005
                • 6170
                not enough Engine, CR or intake manifold to make it worthwhile
                  • 34844
                  go for the 284/272 instead
                  • Brandon12V
                    • 1318
                    no.
                    Originally posted by Ryan...
                    It now emits a beautiful blue-ish yellow/green smoke from the exhaust?? No idea what would cause that color, but I assume its good.
                      • 34844
                      no.
                      you might want to be more clear on who you are responding to..
                      • Brandon12V
                        • 1318
                        To the OP. No.
                        • SpecM
                          • Oct 2005
                          • 4531
                          ^ good street cam
                          1989 cirrisblau-metallic 325i
                          • TimR
                            • Mar 2008
                            • 549
                            Will a 288 + cam pass your emissions where you are, that would suck if not!!
                            • acolella76
                              • 2950
                              +1 i went with a 272 cam and wish i had a 284/272 or just a 284
                              -Alex
