Re-tourque head bolts..
  • e30trooper
    • 11576
    yeah, you just fucked up. if anything its not as tight as it was b4. Your going to need to get a new set of head bolts, they are like 20-30 shipped. This is a very easy job since your not removing the head. Dont go cheap around this kind of stuff.
    • KenC
      King of Kegstands
      • 14396
      I just went through this. Replaing the gasket and using new bolts didn't solve it. I think the head's warped.
      Originally posted by Gruelius
      • e30trooper
        • 11576
        did you tq everything to the right specs ? round 1 ,22lbs . round 2, 90* . round 3 90* ? Clean all that old gasket off?
        Dont worry the side of my block has a lil oil , not as much as it had b4 i did my HG.
        • slammin.e28
          שמע ישראל
          • 12054
          It's just an M20. Geeze. Torque those mother fuckers down!
          • riceh8r
            • Dec 2010
            • 133
            new gasket, new bolts and shaved head + proper torque sequence = no leaks.
            • KenC
              King of Kegstands
              • 14396
              Of course. This isn't my first rodeo.
              • dj01540i6sp
                • Jan 2009
                • 349
                Get a torque wrench and check them, you may have some loose!!! GL
                • KenC
                  King of Kegstands
                  • 14396
                  There's no final torque spec. Also, they're stretch bolts so you can't retorque them.
                  • matt0300
                    • 549
                    +1 for stretch bolts I'm surprised no one said that awhile ago
                    • Adrian_Visser
                      • Jun 2006
                      • 2823
                      It was said, several times. TTY= stretch.
                      '89 Alpine S52 with goodies
                      • dj01540i6sp
                        • Jan 2009
                        • 349
                        How dose any one know if they were stretched properly to begin with? and What dose he have to loose, checking the 90 lb torque to start? GL
                        • E30 Drive By
                          • May 2008
                          • 6
                          Very True Indeed. Metric Blue Maybe?
                            • 34844
                            Its 90 DEGREEES, not 90ft/lbs
                            • matt0300
                              • 549
                              Its like 22lbs then 2 90 degree turns
                              • sweet6e30
                                • Feb 2011
                                • 531
                                :hitler::hitler::hitler:
                                why the fuck is this thread still going, theres a million and 1 places to search for the correct headbolt/hg/torque bullshlakakakaka IF u try to cut corners and fuck around and not do things right the first time obviously YOUR DOING IT WRONG!
                                bentley bentley bentley bentley bentley
                                BENTLEY!
                                my build here ---> http://www.r3vlimited.com/board/show...ht=lemans+blue
