Head options for m20
  • eurotrash86
    • May 2011
    • 19
    Im new to bmws as you can see... but i have to ask, what heads can fit on my m20 2.7? Are there and dohc options?
    Thanks!
    sigpic1986 325entirelyslow
    There aren't any dohc heads for an M20 engine. It is possible to convert an M20B27 into a "budget stroker" by using the head, intake, injectors, AFM, CPS, engine harness, and DME from an M20B25. The result will make more power and have a wider rpm band than a stock M20B27, but less power than that of stock M20B25.
    • warmsquash1
      • May 2011
      • 33
      Just bear in mind that if you do the "i" head on the "e" engine that due to the lower compression ratio it makes this motor extremely reliable with a mild boost forced induction setup of around 8-10 lbs. I plan on going this route actually... There's ways to get the compression ratio back up to stock or more with different crankshafts or custom pistons and rods if you don't want the snailshell or blower. There are dedicated threads on this very subject in the FAQ, engine swap and M20 sections of the site. Read up and see what you want to do...
      :bow:WARMSQUASH1
      "So far, this is the oldest I've ever been..."
      1987 325iC "Bert" - In high tech cryogenic stasis next to John Wayne waiting for a cure for Cancer
      1988 325iC "Ernie" - 5-spd swap is DUN!!!, interior, rims, body kit and kitten sex...
      • kingston
        • Jun 2010
        • 2669
        If you have an `88 325e, you have the Super-ETA motor, and can do this:
        If you have and earlier model, you'd need other additional parts, and would still have a low compression engine.
        Originally posted by LJ851
        kingston is the play by play announcer for this thread.
        ‘Tis by the grace of God that my cars run!
        Originally posted by unloadedak
        #teamross
        Siobhan's Build Thread - UPDATED!
        • e30trooper
          • 11576
          Your wrong! there was a DOHC made for a m20, if you was OG you would have known. Dosnt mean you will ever find one EVER
          • riceh8r
            • Dec 2010
            • 133
            OMG...i want that head, and about 10 more to sell...
            • KenC
              King of Kegstands
              • 14396
              LOL. Jim has forgotten more about e30s than you'll ever know.
              Has anybody ever seen one of those RD heads for sale? Or hell, ever seen one on a car? I feel like this is possibly the rarest e30 part.
              Originally posted by Gruelius
              • SpecM
                • Oct 2005
                • 4531
                There were only a few (like 3 or 5) of those RD heads made... and while they are 24v, I'm 95% sure they were still SOHC
                Sent from my Vortex using Tapatalk
                1989 cirrisblau-metallic 325i
                  • 34827
                  No point in even bringing up that head since it basically doesnt exist.
                  • e30trooper
                    • 11576
                    ive seen one on Ebay a few years back starting for about 7k
                      • 34827
                      Bullshit.
                      • acolella76
                        • 2950
                        wow, you are a douche. That is bullshit, they only made 2 24v heads and scrapped both of them along with the casting. It would cost too much to make for them to even consider going into production.
                        -Alex
                        • e30trooper
                          • 11576
                          Originally posted by nando
                          Bullshit.
                          maybe im mistaken , but your saing they only made two ever... I know it was a very vast amount but im sure they made more tha just two.
                            • 34827
                            They only made prototypes, there was no production run.
                            • acolella76
                              • 2950
                              They made JUST TWO 24v m20 heads, but they cost a ridiculous amount of money for them to make, and then a butt ton more to make them work. You had to convert from timing belt to timing chain, get new pistons because of the different valve reliefs and dome shape, and new engine management. There was no market for them at that high a price so they scrapped the two heads they made and the casting for them.
                              -Alex
