stock cam machined?
  • steezystef
    • Dec 2010
    • 113
    stock cam machined?
    i met up with this guy and he said he had his stock cam machined ( little mod) i guess you can do to make a little more power...is this true? and where could i get it done?
  • JTapper
    • Sep 2009
    • 847
    Turbo Cabrio project: http://eurowerks.org/showthread.php?t=19677
    • steezystef
      • Dec 2010
      • 113
      ...sad thing is i actually have that exact one...will it work? imma buy a junk yard cam to try it on but i dont think i can get all the lobes perfect
      • E30_(1st Musk)_
        • 2008
        • RobertC
          • Dec 2010
          • 127
          Please tell me you are kidding right?
          Your asking for a whole lot of free hassle.
          If you grind the camshaft base circle you will need to get either valve stem lash caps or oversized eccentrics to restore proper geometry.
          Then to add to the problem, you will most likely grind through the hardening and will wipe out the cam in probably less then 1,500 miles if your lucky that it lasts that long.
          If you want more performance, spend your money on a tune up, remove some weight from the car, rebuild your shifter, install some good brake pads, etc.
          Home cam regrinding, really? I imagine some other members here will have some further words of wisdom to express on the subject.
          www.facebook.com/E30motorwerks
          • matt0300
            • 549
            Just buy the super power 366 cam soo much lift!!!
            • Toadleg
              • May 2011
              • 209
              im running on some stock cams that i had reground to about m3 specs. Its been about 5 months or so its my daily driver. m50nv
              • Toadleg
                • May 2011
                • 209
                i thought the m20 cams are inexpensive
                • sweet6e30
                  • Feb 2011
                  • 531
                  why do u want to give yourself a headache , just buy a new one, they're cheap...... DONE!
                  btw, love the tools sarcasm! R3V AWSOME!
                  my build here ---> http://www.r3vlimited.com/board/show...ht=lemans+blue
                    • 37828
                    You can buy reground cams. People will tell you they suck but they're basing their information about what somebody else on the internet told them. I have REAL LIFE experience with 4 M20 engines and 1 M30 engine with a reground cam in them and it's great. Not one of them has needed oversize eccentrics either.
                    Ireland Engineering sells them.
                    Classic BMW Specialists
                    Grover Beach, CA
                    www.BimmerHeads.com
                    • E30_(1st Musk)_
                      • 2008
                      whats the purpose? does it produce more power? im not trolling im seriously asking
                        • 34839
                        eh. I've had them too. They suck for various reasons. Reduced base circle, crappier rocker ratio, more likely to wear due to hardening, and most of them DO require eccentrics. for a budget build they can be fine, but I would never want one.
                        • E30 Drive By
                          • May 2008
                          • 6
                          At least you don't have to buy 2 cams for DOH:-) Do it right the fist time or spend the money twice. I don't think m20 cams are that expensive. 366?????????? Really??
                          • LJ851
                            • 7918
                            This is true.
                            Good for a little extra oomph on a budget.
                            Lorin
                            The M30 is God's engine.
