Are these super eta pistons?
  • Rc 415
    • Jun 2011
    • 723
    They're made by kolbenschmidt, second oversize, 84.48mm and part number ks 90102630 which when I search brings up a corresponding part number of 11251714804, which is a piston in the e series, starting from 09/87.
    1987 Delphin 325IS
    LS1•TSP 228r• condor speed shop solid subframe, diff, fcab, mounts•Airlift air ride suspension•e36 ps rack•Eibach sways•16" Spal puller•bbk 310mm front & rear•17" BBS RS•
    Build Thread
    1993 alpine 2 325IC
    •Ground control coilovers•16" BBS RS• momo woodgrain
  • reelizmpro
    • 9534
    starting from 9/87? would make it an 88 model. Only 88 ETA was the super ETA and the Super ETA has domed pistons like the ones in the picture.
    88 M3 - LACHSSILBER
    89 M3 - ALPINEWEISS II
    • lennon
      • Jun 2008
      • 1416
      from the pictures, i can say they are for the 885 "i" head. they could be for 2.7 crank/rods or 2.5. how would you expect us to tell the difference from your pictures?
      • Rc 415
        • Jun 2011
        • 723
        Well that's why I supplied the p/n references that I managed to find...
        1987 Delphin 325IS
        Build Thread
        1993 alpine 2 325IC
        • digger
          • Nov 2005
          • 6121
          exhaust side valve recess look more like B25 but measure the pin C/L to top.
          • lennon
            • Jun 2008
            • 1416
            well if you have the part number, why are you asking us what they are? there shouldn't be threads asking "what piston is this?", especially when 2 pistons look the same, and you already have a part number! someone putting together an engine should be able to determine these very simple things, not asking a forum.
            /end rant
            • Rc 415
              • Jun 2011
              • 723
              What's the point in being rude? I ask because as stated above the exhaust valve recess looks too big for a seta piston. A forum is to help people, not to get on their case cause they asked a question YOU don't think should be asked.
              1987 Delphin 325IS
              Build Thread
              1993 alpine 2 325IC
              • reelizmpro
                • 9534
                How do you figure? The super ETA uses the SAME head and valves as the 325i. It would make sense that the relief is the same size. Do you have a stock Super ETA piston next to you for comparison?
                88 M3 - LACHSSILBER
                • digger
                  • Nov 2005
                  • 6121
                  if the reliefs of SETA and I were the same it would most likely be that the crown would be the same. Given the SETA has more cc and much the same compression this does not add up.
                  A SETA piston
                  • StereoInstaller1
                    GAS
                    • 22679
                    A SETA piston
                    same bore though, so IMO, reliefs should be the same.
                    You may have to shove those in a block.
                    Closing SOON!
                    Thanks for 10 years of fun!
