C191 - big round connector under the intake manifold.
Check it for corroded terminals or broken wires. Should easily twist apart.
If going bad or corroded, it can cause many intermittent problems such as split second cut-outs, bad idling, and hard starting.
Mine was completely locked together and I had to cut it out and put in bullet connectors. I had to saw the connector in half on the bench before it released its rusty grip, it should have been an easy twist.
If you already know about the C191, please go smear so dielectric grease on it right now.
If you don't know about it, check it out, it may be causing your idle/rev/start problems!!!
Just thought I would post this because I couldn't believe how many issues servicing the C191 solved for me.
