Low Compression M20 Engine
  • QWKE30
    • Oct 2009
    • 51
    1989 325i 150k+ miles
    Manual transmission
    After a diagnosis of low compression I had a valve job done and changed the sparkplugs and we got a slight improvement.
    Original compression check =========== Compression check after work.
    Cylinder 1 110 =========== 1 120 9% gain
    Cylinder 2 110 =========== 2 110
    Cylinder 3 110 =========== 3 110
    Cylinder 4 105 =========== 4 110 5% gain
    Cylinder 5 105 =========== 5 110 5% gain
    Cylinder 6 105 =========== 6 115 10% gain
    What is the proper compression for this motor?
  • bmwstephen
    • 2463
    supposedly 150 range but its very subjective. how did you do the compression testing? I assume the low but consitant numbers mean that while you were cranking for the test, you did not apply WOT
    • QWKE30
      • Oct 2009
      • 51
      My mechanic did it, he didn't say how.
      • slammin.e28
        שמע ישראל
        • 12054
        Ask.
        • QWKE30
          • Oct 2009
          • 51
          wet
          • ForcedFirebird
            • Feb 2007
            • 8300
            Those numbers look fine for an engine with miles. Alldata says a new m20 should have 142-156psi with a maximum of 60% variance (lowest cylinder should be 60% or more of highest cylinder), engine warm, throttle open.
            john@m20guru.com
            Links:
            • Jaxx_
              • Dec 2009
              • 1880
              60%? that seems a bit ridiculous.
              If the 2nd number is wet, looks like just a valve train issue -- I would do a valve adjustment and re-test. 110psi is rebuild territory for most motors.
              edit: yeah, I just saw that the 2nd number was after a valve adjustment. I would re-test with it wet and see if there is a vast improvement. if there is, rings are worn.
              I've never gotten a huge variance from throttle open and throttle closed. the motor is not spinning more than 300rpms anyways. Just to give you an idea -- megasquirt will ready about 97kpa when cranking before the car fires. Not exactly far off from full throttle. cyls fill with air pretty quick.
              edit #2: so were all the tests done wet? was the motor warm? I don't even understand the full testing procedure. Seems pretty stupid to just jump to putting oil in the combustion chamber to see what your compression numbers are.
              • ForcedFirebird
                • Feb 2007
                • 8300
                He had a valve job done, unless the lash was adjusted extremely wrong, it should be sealing.
                I have had several m20's in the shop with 110-120psi and run just fine (street/daily cars).
                Totally agree with you on the throttle plate, opening it only seems to make the needle go up faster with similar numbers in the end with it open/closed.
                As long as the cylinders are consistent, I don't follow alldata's 60%, I like to see less than 20% variance.
                It takes only 80psi cranking to make fuel combust BTW. I have seen an m20 running at 90-100psi on all 6 lol.
                john@m20guru.com
                Links:
                • Jaxx_
                  • Dec 2009
                  • 1880
                  I agree with your post, but when the motor should be sitting at like 160+ from the factory (even these stone age motors) I wouldn't want to have 110psi. The good thing is that the motor has worn evenly but the truth is that even if a car runs fine it doesn't mean it's to it's full ability. For getting around town even an oil burning piece of shit will do.
                  • slammin.e28
                    שמע ישראל
                    • 12054
                    I have an old Willys Jeep 4 banger and it has an even 30psi across all four cylinders.
                    It ran.
                    It also puked blue smoke, but it ran.
                    • ForcedFirebird
                      • Feb 2007
                      • 8300
                      Factory manual states 156psi. I will stick with experience. These cars are old and have only seen ONE come in the shop that had 125 on 5 and 120 on one. If the OP is satisfied with a decent running car, I wouldn't say that a rebuild is req'd is all I meant.
                      It ran.
                      lol. I have never seen anything run on that low cranking pressure. Have seen some low numbers with cams too big for the compression ratio, but never that low.
                      john@m20guru.com
                      Links:
                      • Jaxx_
                        • Dec 2009
                        • 1880
                        agree. I have ~145 across all 4 of my M10.
                        • digger
                          • Nov 2005
                          • 6119
                          i had 150psi +/-5 on all my stock B25 cylinders with 110k on the clock
                          • Galactodactyl
                            • 182
                            142-156 PSI is what the Bentley manual says.
                            Last compression check I did was 164/155/160/128/155/155.
                            270k on the clock 89 325is.
