new better fuel pump now starting issues...HELP!!!
  • custom e30
    • Nov 2009
    • 347
    i have a 1988 bmw 325i convertible, i turbocharged it, it only has the 19lb injectors in it so im not running anymore then 7psi at the moment, so just to add a extra free upgrade to my car i figured i would put a new tre performance 340 255 fuel pump in my car,
    my prob is that now it take alot of cranking and gas pedal play to get it to fire up, i dont see why a 100psi fuel pump with cause the car to not wanna start so im just curios to know if anyone has any clues on this issue,
    help is appreciated, thanks
  • custom e30
    • Nov 2009
    • 347
    wow no help
    • Farbin Kaiber
      Lil' Puppet
      • 29502
      Originally posted by custom e30
      wow no help
      rrfpr.
      • custom e30
        • Nov 2009
        • 347
        hmmmmmm....
        • Kershaw
          • 11822
          :rofl:
          if you put the old fuel pump back in, does it start fast again?
          AWD > RWD
          • Farbin Kaiber
            Lil' Puppet
            • 29502
            Did you replace the fuel filter when you installed a new pump?
            • custom e30
              • Nov 2009
              • 347
              idk if it will start fast again or not if i put the old one in, and i replace the fuel filter 6 months ago
              • redsubdivisions
                • Feb 2011
                • 1762
                lmao Farbin.
                Check the fuel pump sock. If you didn't replace that, chances are its that.
                1989 325i - 2.7i, Holset H1C, 60lb injectors, whodwho MS-PNP.
                2012 Passat TDI - DD Duty
                2008 GMC Yukon XL Denali - Kiddie hauler/grocery getter
                • Gary Horneck
                  • May 2011
                  • 435
                  I have the same fuel pump and the same cranking issues. All the pressure leaves the fuel rail after a couple hours, and it takes some cranking to get pressure back. I have an adjustable fpr with gage, so after it re-pressurizes, its fine.
                  2011 335i/1995 Mercedes C220 (rallyx)
                  • custom e30
                    • Nov 2009
                    • 347
                    see that confuses me, the new fuel pump should add more pressure. faster?
                    • Farbin Kaiber
                      Lil' Puppet
                      • 29502
                      Do you know the difference between dead-head and return systems?
                        If the new pump doesn't have a check valve or if the FPR or injectors are leaking the fuel rail will lose pressure when the engine is off. With a good OE pump the rail should see normal pressure in just a few turns of the engine, even if the rail pressure starts at zero. But if the injectors are leaking, you'd still be faced with flooded engine and a good number of turns of th engine would be required to clear the engine.
                        The pump you fitted may have higher pressure, but a lower flow rate and might be missing the check valve. Replace that trash with a new OE pump. And make sure that the FPR and injectors aren't leaking.
                        • custom e30
                          • Nov 2009
                          • 347
                          got yea
                          • custom e30
                            • Nov 2009
                            • 347
                            just ordered jdm fpr, the hunt continues tomorrow for the 30lb injectors at the jyard, anyone got any ideas on what vehicles will have them???
                            • u3b3rg33k
                              • Jan 2010
                              • 2452
                              who the fuck post this?
                              and this:
                              Ich gehöre nicht zur Baader-Meinhof Gruppe
                              Originally posted by Top Gear
                              Just imagine waking up and remembering you're Mexican.
                              Every time you buy a car with DSC/ESC, Jesus kills a baby seal. With a kitten.
