overheated. Now runs kinda rough. Thoughts?
  • shiboujin
    • Feb 2006
    • 2791
    spun into a tire wall but no damage. Somehow the upper coolant hose sprung a leak. Fixed it real fast, topped up the coolant and went back out.
    I've got the car back from the track but it idles kinda rough now and hesitates to rev. Drives fine. It's just the on throttle response is kinda meh and the engine shakes like a mofo. Any thoughts as to what could be wrong?
    The impact with the tire wall may have created an intake leak. Also take a critical look at the motor and transmission mounts.
    • nates 87 325is
      • Jun 2011
      • 124
      When i had a broken rocker arm, I had the same thing going on. May have broke from the overheating.
      87 325is
      • shiboujin
        • Feb 2006
        • 2791
        compression is 150/160/150/140/155. Of course, now I realize I forgot a cylinder...
        Every cylinder has spark. When I pull each wire the car def idles differently. The car does sound like it's missing on one cylinder.
        I'll finish the comp check tomorrow, it'll show if I have a broken rocker arm. That and I'll yank the valve cover.
        • scottinAZ
          • Dec 2009
          • 1312
          depending pn the degree of the overheat, you may have lost a head gasket. damn finiky M20's
          I saved 15% on my Bimmer parts by switching to ...
          • shiboujin
            • Feb 2006
            • 2791
            All the rockers are in tact. I don't think the HG went. no oil in coolant or coolant in oil. *shrugs* wtf?
            • Vtec?lol
              • Dec 2009
              • 3278
              just because you don't have mixed fluids doesn't mean you don't have a blown head gasket.
              • shiboujin
                • Feb 2006
                • 2791
                Dude, you're so right. I should just do the HG.
                • Beach Bum
                  • 466
                  This is the shit I don't get. You make a thread asking for help, and then get all butthurt and sarcastic when you don't hear what you want to hear. If something irks you, ignore it and move on.
                  He is absolutely correct in saying that a blown HG does not necessarily mean you will get mixed fluids. If it's an external leak (cylinder to atmosphere) you still lose compression and it will run rough.
                  Have you checked for vacuum leaks yet?
                  If people keep quoting me in their sig, I'm going to burn this motherfucker down.
                  • shiboujin
                    • Feb 2006
                    • 2791
                    I'm not butt hurt. The statement does me no good. I want to check everything before assuming it's the head gasket. There was no extra pressure in the cooling system, no loss of oil or coolant so all signs point to it not being the HG. With an engine running as rough as mine was, there would have to be something getting into something where it shouldn't be.
                    • Beach Bum
                      • 466
                      So are you going to check for vacuum leaks or not?
                      • shiboujin
                        • Feb 2006
                        • 2791
                        cyl 5 had no spark. it was a bad dist cap. Even though I only had it for less than a year.
                        • Beach Bum
                          • 466
                          Glad to hear you got it taken care of.
                          • Vtec?lol
                            • Dec 2009
                            • 3278
                            lol, I wasn't suggesting that it was your headgasket.
