Schrick
  • jules325i
    • Jul 2011
    • 353
    Schrick
    I'm building a 2.8 stroker and have come to the point of choosing a cam.
    I don't want anything ridiculous, because it will be my daily drive.
    I have narrowed it down too the 272 degree Schrick Camshaft
    and the Cat cams 264 Degree camshaft
    Is anyone running either of these and can give me feedback.
    329i
  • Myster-E
    Performance
    • 552
    I have a 2.8 m20 with 9.8CR and I am running a reground 280 cam and I love it. I didn't have to run bigger eccentrics either.
    1988 E30 335i - 1987 E30 327i - 1987 E30 327iS Pickup - 1973 2002 Project
    Visit www.BimmerHeads.com for all of your 12 valve needs!
    • matt0300
      • 549
      Call them up and have them make u a 366 racing cam
      • Myster-E
        Performance
        • 552
        Shit why not just grind the cam yourself with a grinder?
        • jules325i
          • Jul 2011
          • 353
          Thanks that was helpful idiot
          329i
            • 37833
            The 264 is practically stock. Go with a 272 bare minimum but as mentioned by Myster-e something around 280 would be beneficial to a 2.8L.
            Grover Beach, California
            BimmerHeads.com
              • 37833
              LOL :rofl:
              BimmerHeads.com
              • deansbimmer
                • 674
                Go with a 280. The 272 is pretty tame. I wouldn't even bother with the 264...
                • acolella76
                  • 2950
                  yeah, 264 is stock for a 323i. So that's not even worth the money.In my experience 272 is pretty mild, 284 would be my choice.
                  -Alex
                  • bmwguy325is
                    • May 2011
                    • 1263
                    • 272 degree for Street & Daily Driver
                    • 284 degree for Hi-Perf. Street or Mild Track setup
                    • 288 degree for Track use or max perf. street
                    • 304 degree for Race use at high RPMs
                    Duration: 272° / 272°; 284° / 272°; 288° / 288°; 304° / 304°.
                    sigpic"If one does not fail at times, then one has not challenged himself." -Ferdinand Porsche
                    The ugly car: http://www.r3vlimited.com/board/showthread.php?t=209713
                    • jules325i
                      • Jul 2011
                      • 353
                      Ive been watching vids of the 272 idle and it sounds like a fucking tractor is that because they didn't increase idle speed.
                      329i
                      • digger
                        • Nov 2005
                        • 6153
                        the catcam 264 is not practically like stock, the 264 is the advertised duration which means little. The 264 is 227@1mm+cl and the stock M20 cams are around 215. The schrick 288 is about 242 so the catcam 264 is pretty much the same as a 272ish schrick duration, lift is similar aswell as asi lift at TDC only the LSA differs by 2 degrees........
                        Have a look at dbilas they have some more variants in the 270-280 range which offer different LSA and lifts
                        What CR will you run and what are the specs of the engine?
                        • jules325i
                          • Jul 2011
                          • 353
                          2.8 CR 10.5:1 and just trying to choose the right cam. the 272 is looking the goods.
                          329i
                          • jules325i
                            • Jul 2011
                            • 353
                            So the 272 will be fine to drive in town and i won't lose much low down torque.
                            329i
                            • digger
                              • Nov 2005
                              • 6153
                              should be fine from that perspective, could even get 284 with that much compression and might be less prone to needing 93
