3 angle valve job
  • EThirty318i
    • Dec 2010
    • 219
    3 angle valve job
    I have the chance to get one, is it worth it? pro's con's?
  • deutschman
    • May 2008
    • 5958
    I had one done with a 30/45/62 intake and 30/45/60 exhaust. Any more angle on the third cut makes the angle almost horizontal. It is hard to enplane when I am not looking at it. I did a lot of talking with a VERY good machinist and he said that those angles would work best with the head I had and the way it was originally machined by BMW.
    Any ways if you can get it done do it. It is one of the more noticeable things you can do to an m20 head. I would say go for it.
    • EThirty318i
      • Dec 2010
      • 219
      Thanks! and i was just looking at your build thread and noticed you had a 3 angle valve job done haha. BTW I'm in awe! that is awesome! good job! and thank you for the help!
      • deutschman
        • May 2008
        • 5958
        no problem. make sure you find a real good machine shop that is willing to talk you threw what you are doing. if the guy does not want to talk about it, or even tries to blow you off, find a new guy. i feel if the person doing the work is not interested in what he is doing and loves to talk about it he will do a bad job.
        • Dj Buttchug
          • Jun 2010
          • 7688
          theres alot of theory about angle cuts on valve seats ect. Heat transfer is a big deal as well as the valve sealing correctly. Most shops with 3 angle cut anyways. Its vey common.
          If your building something for power or boost consider a 5 angle job. More surface area of the valve comes in contact with the valve seat surface thus transferring more heat and creating a better seal...if your just refreshing a 3 will do fine.
          Turbo M42 Build Thread :Here
          Ig:ryno_pzk
          I like the tuna here.
          Originally posted by lambo
          • deutschman
            • May 2008
            • 5958
            Its also a lot about air flow and reducing interruptions in the flow of air and/or air turbulence. The less extreme angles the air coming into your engine has to move over the better. This is also why many people will try and "port" the intake runners to try and reduce the angled surfaces the incoming air has to flow over. That is a very simple explanation of the idea. Five angle jobs can be a bitch to do, and might not even be possible depending on the head, and the condition the head is in. There is only so much material and surface area to work with.
            • EThirty318i
              • Dec 2010
              • 219
              Thanks guys! that really helps!
              • digger
                • Nov 2005
                • 6199
                its best do do these things on a flow bench, unless you know someone who already knows what works best from a good deal of experience on the exact head you are using
                • SkiFree
                  • Jun 2011
                  • 2766
                  ^^^ x2, otherwise it's an unfortunate case of the blind leading the blind. Find someone local who's willing to take you on as a grunt for a bit in exchange for knowledge.
                  ADAMS Autosport
                  • deutschman
                    • May 2008
                    • 5958
                    The angles I used were resurched and recommended by a very experienced machinist.
                    • browntown
                      • Jun 2004
                      • 3524
                      I'm no physicist, but I've talked to lots of guys in the hotrod arena and there seems to be some debate about this. Some guys say turbulence in the intake path is fine if not helpful. The engine builder paul burke I talked to over on mye28 and on the phone has pretty much talked me out of port matching the b35 intake to the m90 head. I forget the details but he did testing for Mopar? in the 60's? on the very subject and found the step in the intake flow did nothing adverse. I'm sure I have the story wrong a little, but I remember him telling me about wasteful and meaningful engine work.
                      You can see his engines on the net. He's a pro
                      • digger
                        • Nov 2005
                        • 6199
                        experienced with what specifically works for M20 heads for improved performance or just alot of years machining stuff? there is a difference
                        • Wanganstyle
                          • 2828
                          here is a properly done m20
                          exh side clean up (slight to match headers)
                          chamber:
                          Intake side opened up:
                          engine specialities head (RIP Dave cruz)
                          • digger
                            • Nov 2005
                            • 6199
                            chamber:
                            pics don't seem to work?
                            • jamesthebikeguy
                              • Jul 2011
                              • 158
                              What does a Valve job like Deutchman cost?
                              95 Ford PSD : 99 540i M-sport : 89 325i
                              e39 Rear Muffler Delete Exhaust Video...BMW 540i/6 Fort Devens AutoX, IN-CAR Video...Learn to Re-finish your Headlights (Click for Video)
