"I" vs "E" Rods
  • jules325i
    • Jul 2011
    • 353
    "I" vs "E" Rods
    Are there any advantage in using "I" conrods in my stroker project over the "E" Rods.
    329i
    • 37828
    Well, they are different lengths. It all depends on what pistons you are using.
    Classic BMW Specialists
    Grover Beach, CA
    www.BimmerHeads.com
    • acolella76
      • 2950
      Yep. Depends on pistons and crank. I rods are 135mm and Eta rods are 130mm. Unless you are building a 2.7L or 2.8L use M5x rods. they are the same length as I rods but are a lot lighter.
      -Alex
      • MCG89
        • Aug 2011
        • 10
        arent the I rods a lot stronger than the E rods as well?
        Hi :D
        The daily: 2010 MAZDASPEED 3: bolt ons :D
        #1 project: 96' MX-6 M-edition: Borg Warner turbo :D
        #2 project: 87' BMW 325 :D
        • MonkeyMadness
          • 3251
          I rods a 135mm
          E rods are 130mm
          • acolella76
            • 2950
            Originally posted by MonkeyMadness
            I rods a 135mm
            E rods are 130mm
            he said stronger, not longer ;) To answer the question: not a huge difference if any.
            -Alex
              • 34839
              no.
              to answer the original question - use the longer rods. unless you're doing a junkyard build with used stock pistons, then you could be stuck with the 130mm rods.
