Anyone run this intake yet?
  • bmwguy325is
    • May 2011
    • 1263
    Im guessing it is more for a turbo car than anything.
    sigpic"If one does not fail at times, then one has not challenged himself." -Ferdinand Porsche
    The ugly car: http://www.r3vlimited.com/board/showthread.php?t=209713
  • Eecen
    • Jun 2010
    • 1235
    Revshift's intake manifold designs take advantage of high air-flow characteristics, inertial effects, and pressure-wave tuning to achieve air density in cylinders that substantially exceeds the oem intake manifold.
    Sure sounds mighty fancy.
    Picture is not actual product only sample!
    • acolella76
      • 2950
      I would much rather have the 666fab intake
      -Alex
      • accident
        • 7303
        lol
        Moral of this story?
        • bmwguy325is
          • May 2011
          • 1263
          So Im guessing this is only turbo only? Guess I can call them.
          • matt0300
            • 549
            What lol its for n/a motors. Why would u need an intake for FORCED induction?
            • digger
              • Nov 2005
              • 6216
              based on what? there are no details of this manifold.
              • bloodshot-e30
                • 1494
                the one pictured looks like its for a VR
                ^Back in the game^
                BUILD THREAD: http://www.r3vlimited.com/board/showthread.php?t=201281
                FS thread:
                http://www.r3vlimited.com/board/showthread.php?t=214105
                • Jette_man
                  • Mar 2008
                  • 18
                  I would say this is better for na purposes. With a very aggressive engine ie higher compression fully worked head and a higher rev limit gains could be seen. Without specs its hard to say. Short runners=high end power gains. Short runner intakes give less overall gains on forced induction. Top end power shouldn't be an issue since air can be forced through a longer runner intake on the high end (under boost) and a longer runner intake will increase lower rpm ve when not under boost. This is very generic but mostly remains true.
                  • ROLLingKING
                    • Apr 2011
                    • 1169
                    it says the pictured product is not actual product..but if its anything similar which it probably, it would work better. suck in more air not just at your throttle body but start at the whole manifold.
                    and they say u should have air/fuel tuning capabilities. it sounds like it allows u to increase and play with numbers. which = power
                    m20 is plenty. im simply a drifter.
                    build thread -- http://www.r3vlimited.com/board/showthread.php?t=206510
                    • digger
                      • Nov 2005
                      • 6216
                      what does this mean?
                      it sounds like you just need to retune it, and if you didn't then it most likely didn't do enough to justify $845.
                      • bmwguy325is
                        • May 2011
                        • 1263
                        Might be worth trying out. I am curious about if you run the OE throttle plate oe what. Guess I can call rev shift
                        • george graves
                          • 20003
                          Well, at least Ary is consistent.
                          Originally posted by Matt-B
                          • LowR3V'in
                            • 4209
                            He'll sell at least 1 if he used the actual picture.
                            Some lazy vendor.
                            http://revshift.com/shop/intake-manifolds/bmw.html
                            Nevermind looks like it's a pre-order thing?
                            • bmwguy325is
                              • May 2011
                              • 1263
                              Some lazy vendor.
                              Either that or he has not yet sold a production quality one/....
