So my car has been slowly raising temp at idle and low speed traffic and after some research i'm assuming its the clutch fan (gonna do the newspaper test tomorrow), while i'm down there replacing it, anything else I should check/replace/adjust/(insert maintenance action here)?
clutch fan replacement, couple questions
if its the clutch fan your temp would sky rocket at low speed. maybe you had a stuck open thermostat or the PO took it out. it would cause continuous water flow which result in low temp.Comment
did you try to the newspaper test? Have you tried just pushing it and seeing what kind of resistance it offers?I want a nice set of smoked MHW's (I know, get it line)
While you are driving have your window down and see if you can hear the fan staying engaged. the sound is distinct as it sounds like your blower fan on high speed as you accelerate. Not all clutches stop hooking up. Some stay hooked up and this puts load on the engine. usually affect fuel consumption.sigpicComment
Clutch fans can go bad slowly and only cause your temp to increase a little while not moving. Cheap enough part, replace, profit.Comment
- Josh
1990 325is
Need a shift boot?
Looking to buy shift boot frames, PM if you have one to sell
Here's what happens when you let the internet pick your license plateComment
what year is your e30?
the e30 with m42 motor can use this,e36 electric radiator fan for 60. plug and play.
http://www.pelicanparts.com/cgi-bin/...ch%20%20%20%20
wow they jacked the price up to 100Last edited by immajackuup; 10-20-2011, 08:04 AM.Comment
clean the fins? ive flushed but i never heard of fins.lol
*edit: oh the fan fins.....haha. i guess dudem20 is plenty. im simply a drifter.
build thread -- http://www.r3vlimited.com/board/showthread.php?t=206510Comment
