How hot do you get?
  • iansane
    • 1341
    How hot do you get?
    Since I just bought my first m20 equipped e30 and it doesn't have an actual coolant temp gauge, I've been trying to keep an eye on where it sits 'normally'.
    Where does the needle point for you guys?
    84 325e - 91 325i - 92 318 touring - 91 Trans Am - 01 S4 avant - 03 S-type R - 96 F350 - 15 SS - 84 Biturbo - 91 Defender
  • CHIF8008
    • 3447
    back side of the middle mark
    -FREEDOM- is cruisin at 80, windows down and listening to the perfect song-thinking "this is it"
    -The Beauty in the Tragedy-
    MECHANIC SMASH!!- (you all know you do it)
    Got Drop?? ;-)
    But of course
    E30s are know to be notoriously really really really ridiculously good looking
    • Sagaris
      • Sep 2009
      • 2243
      When the ambient temperature is below 60F my car will run 1.5 to 2 needle thicknesses below the 1/2 mark. This is due to removing the A/C condenser
      When the ambient temperature is below 90F my car sits at the 1/2 mark or a needle thickness below the 1/2 mark. When the temperature is between 90-100F the car runs at the 1/2 mark and creeps up a needle thickness past the 1/2 mark once I get off the freeway and come to a red light. (I have no aux. fan).
      I am thinking of running a thermostat which allows me to run a tad hotter.
      • Thehemiman
        • Apr 2009
        • 533
        Mine sits at 1/4 when its at regular running temp. If I'm sitting in traffic it will creep up though. I need a new fan clutch...
        1988 325i Vert
        1991 318is Slicktop
        • yert315
          • 2734
          depends. If im going out that night, I get pretty spiffy.
          Middle of the gauge.
          • djjerme
            • 5082
            I get sexy hot in direct relation to how much beer consumed.
            2016 Ford Flex
            • cabriodster87
              • Jan 2011
              • 1042
              If there were a 1/3 mark, that's where mine averages. If i see it past the 1/2 mark, that would be the first time.
              Reich und Roll!
              • TurboJake
                • 3780
                Dead center half mark. No deviations once warmed up.
                Leave Me Transaction Feedback
                • tAngo.
                  • Oct 2009
                  • 441
                  mine jumps all over the place...
                  TEMO
                  Originally Posted by Ryan... If you've seen Tango's girl, you would not be questioning his choice of apparel ;-)
                  • Kershaw
                    • 11822
                    just shy of 1/2. there really is no standard for this.
                    just a standard for what your car does.
                    AWD > RWD
                    • iansane
                      • 1341
                      Seems to be a pretty good spread for how hot. Has anyone figured a correlation to what's indicated on the idiot gauge vs actual temperature?
                      Mine seems to get pretty warm (as in the upper half all the time and sometimes even the upper 3/4) but I'm not sure the cooling system is completely burped yet. I had left the clutch fan off for a few days while I figured a way to get a proper sized spanner on the nut and it actually seemed to run colder w/o the fan. Never left the half mark.
                      • stillkotd
                        • May 2011
                        • 127
                        Mine is almost always right at the 1/2 mark. If I drive hard and then wait at a stop light it might creep up half a needle width or so, but I've never seen it any hotter than that.
                        1989 325i m50b25tu swap
                        1989 325i (sold)
                        • rodpaine
                          • 33
                          Temperature Gauge approximate degrees F
                          Rod's 528e support web site
                          A car can be restored many times. It is original only once.
                          • BlueIX
                            • May 2007
                            • 755
                            Prior to having my timing belt, water pump, radiator and thermostat replaced I'd start creeping past the half way mark when stopped in traffic and the temperature was 80+ degrees. Now the car pretty much stays below the halfway mark,
                            Originally posted by BAlbertiX
                            your my boy blue!
                            • iansane
                              • 1341
                              Originally posted by rodpaine
                              Thanks!
