How hot do you get?
  • funcrew
    • Jun 2007
    • 1223
    Never budges off 1/4 gauge, even in stopped traffic in Las Vegas at 115F. Bone stock 325i with new fan clutch, water pump, and thermostat.
    "If the sky were to fall tomorrow, the tall would die first."
    -Dr. Paul Forrester
    Do I LOOK like I need a psychological evaluation???
    • LJ851
      • 7919
      always at 1/2 give or take 1 needle width in either direction for the last 100,000 miles.
      Lorin
      The M30 is God's engine.
      • Cletonius
        • 2809
        Originally posted by iansane
        Mine seems to get pretty warm (as in the upper half all the time and sometimes even the upper 3/4) but I'm not sure the cooling system is completely burped yet. I had left the clutch fan off for a few days while I figured a way to get a proper sized spanner on the nut and it actually seemed to run colder w/o the fan. Never left the half mark.
        How old is the clutch? Did you do the newspaper test?
        Are you sure the fanblades are on the clutch the right way? My uncle told me one time a car came into his shop that would sit stationary and not overheat, run normal temps when moving, but overheat when creeping in traffic. Turns out someone had wired the efan (no mech fan either) backwards so at low speeds it would create an air cushion at the front of the car and no air would move through the radiator. He said he figured it out when by chance the fan came on and blew a workorder out of his hand.
        - Josh
        1990 325is
        Need a shift boot?
        Looking to buy shift boot frames, PM if you have one to sell
        Here's what happens when you let the internet pick your license plate
        • Sagaris
          • Sep 2009
          • 2243
          For all you guys that are proud that your temperature never gets close to 1/2, change your thermostat to one that is stock spec and enjoy the power that comes from running a car at the correct temperature. The hotter your engine runs, the more efficient it is.
          • kid325e
            • Sep 2007
            • 6422
            Originally posted by stillkotd
            Mine is almost always right at the 1/2 mark. If I drive hard and then wait at a stop light it might creep up half a needle width or so, but I've never seen it any hotter than that.
            Me too, and I know for sure my fan clutch is on it's way out.
            clutchCTRL!
            Move with a purpose.
            - 1991 325iX 4dr/5spd
            - 2000 323i AT
            2016 Mazda CX3 Sport AWD
            • NC325iC
              • Mar 2004
              • 6565
              1/4 mark, rarely above that, in which case the electric fan kicks on and brings it back. with my new IE all alum radiator it rarely needs the fan to kick on.
              • boxen
                • Jul 2011
                • 14
                I just went through my cooling system last weekend, and replaced the water pump, thermostat, and fan clutch.
                Before this, my car ran rock-solid at halfway, but crept up past there if I was stopped, or in slow traffic.
                Now, the gauge reads maybe a needle's width below the 1/4 mark with ambient temps of around 60 F. This seems too cool to be normal to me, and it's vaguely worrisome since I intend to drive it during the winter when it'll be far below freezing.
                Anyone have any input?
