Oil. synthetic vs. mineral oil
  • z122643
    • Aug 2011
    • 286
    So I have an iX with the M2025B engine. I've been using 15w40 Castrol (mineral) and I wanted to switch to synthetic. I'm just completing a complete engine rebuild so I thought I would get some opinions.
    Mobile 1 says to use 0w40 synthetic. What weight synthetic is best for an California climate?
    [/SIGPIC]"we are so totally screwed!"
  • Cletonius
    • 2809
    Where in CA? If I was in socal I would run 20w40 all year.
    - Josh
    1990 325is
    Need a shift boot?
    Looking to buy shift boot frames, PM if you have one to sell
    Here's what happens when you let the internet pick your license plate
    • z122643
      • Aug 2011
      • 286
      I live in SoCal and NorCal. I will be in temps between 30F-100F
        For temps that don't go below freezing, you want a 20w50 oil. There is no reason to use synthetic in an E30 since the oil/filter changes need to be at the factory interval. The longer life of synthetic oil can't be taken advantage of on these engines.
        • Apps
          • 175
          Lubricity is a clear advantage of synthetic oils no matter what the service interval. It's been written up many times before and does depend on the base stocks used but synthetic will always provide better lubrication for a given ppm. There is a reason race cars are using different synthetics then you're off the shelf Castrol or Mobil 1...
          • KenC
            King of Kegstands
            • 14396
            If it's a DD and you're not tracking it, just run 20w50 dino for diesel engines. They have a really high ZDDP content.
            Originally posted by Gruelius
              • 37833
              Another vote for 20w50. There is absolutely no need for synthetic in these engines.
              Grover Beach, California
              BimmerHeads.com
              • HR2L
                • 724
                Another vote for 20w50 non-syn. I use the Valvoline VR-1 non-syn oil as it has higher levels of ZDDP and it seems to work good. Castrol GTX High Mileage seems to be another highly used oil for our cars as well. :)
                • Cabriolet
                  • 9620
                  im with MR325. really its not about synthetic or non-syn. its about changing it often every 2700-3200 miles. in Ca, 20w50 is perfect year round.
                  personally i use full synthetic 10w40. i have a fresh rebuilt engine and push it autoX and drive like an idiot 5 days a week. but i still change mine every 2500 miles.
                  Much wow
                  I hate 4 doors
                  • HR2L
                    • 724
                    Agreed. I usually change my oil every 3k-3500 miles (DD my e30). Sometimes I run a little blend (weight) I will do 3.5qts of 20w50 and 1.25qt of 10w40 during the winter time. ;)
                    • MonkeyMadness
                      • 3251
                      yep yep...
                        • 37833
                        VR-1 is AWESOME. Definitely pricey but a really great product. I use it in my M20.
                        BimmerHeads.com
                        • aTron12
                          • Nov 2009
                          • 98
                          I'm up to 240K and am running 20-50 synthetic.
                          • JrCamacho
                            • Feb 2011
                            • 618
                            ZDDP!
                            20w50 here, and my m20 loves it.
                            • digger
                              • Nov 2005
                              • 6171
                              I am not sure how you guys can say one oil is better than the other without having tested them scientifically. The fact is most manufacturers are sketchy as to what is in the oil.......
