Car will still start with a broken rocker. Drove my old one with one for 3 months.
Car Wont Start! Need Help ASAP
UpLast edited by AsharC; 12-13-2011, 05:19 AM.
BUY MY WHEELS! BBS E50s!!
http://www.r3vlimited.com/board/showthread.php?t=275407
Originally posted by Lurker27Any man will tell you being blown is better than being stroked.Comment
Up.
I replaced the belt in April, would it have gone bad that fast? or faulty belt?
Bump.
Zhe cams are spinning.
Are the flywheel sensors really ok? Did you buy new ones or test the ohm value on them? It's a 325e right? So there are 2 in the flywheel housing. If these are dead or you just replaced them with junkyard sensors the fuel pump or DME won't get any power.Comment
I replaced the sensors with working ones. Still the same problem
Bump.
"Well did you check the CPS"
"yup, its fine"
"bump"
"bump"
"bump"
"Well did you see if the pump runs while starting"
"yup"
"bump"
Did you check to see if the coil..."
"Yup still won't"
"bump"
"bump"
"bump"
I just find this conversation funny.
OK OP how about this, why don't you tell us what you haven't done, checked, or replaced yet.
That way we can narrow down the problems that we have and haven't covered otherwise we might just give up and the thread will be unfinished. Try making a list of whats not been done so far.Comment
i have this exact same problem on my 1984 325e shitty business. the amount of oil its leaking is crazy. time to pull it out and get to work i guessComment
Mine too. Idk if it oil or trans fluid. Its leaking in the back of the bay.
