Adjustable Cam Gear / Doesn't fit - help
  • SELfor50
    • Jun 2011
    • 19
    Hi All,
    Got this from e-bay;
    Says fits all M20. They've apparently sold tonnes them no issue.
    This one, see photos.
    New Timing Belt with sprocket from 323i/731 head
    Same belt with new adjustable sprocket/cam gear
    Also been told that the 318i engines use same sprocket / cam gear... which confused me a little.
    Help please. I definitely have the right belt. Seems the teeth are too wide on the adjustable one.
  • stoker1010
    • 10
    I have the same cam gear and a new belt ready for the next belt change. I have just tried the fitment as well and it appears to have the same problem as yours.
    Have to keep us updated if you find a solution.
      • 37833
      Ditch that China junk and leave it stock, seriously.
      Also, the 318 definitely does not use the same gear. They are not timing belt engines.
      Grover Beach, California
      BimmerHeads.com
      • stoker1010
        • 10
        I know what your saying. I have a schick cam in and I wanted to play around a bit with cam timing. Looks like the stock gear will stay on.
        I would rather do that than chance trying to stretch to appear to fit and then find it jumping teeth.
        • whodwho
          • Jun 2008
          • 1547
          If you use the stock one make sure to get one that is not stamped steel like that one.
          My M20 Frankenbuild(s)
          4 Sale - Fully Built TurnKey Megasquirt Plug and Play EMS
            • 37833
            Good point, the one from the B25 is much nicer.
            BimmerHeads.com
              • 34844
              the M40B18 abd B16 uses a belt.
                • 37833
                Shit, I always forget about those.
                BimmerHeads.com
                  • 34844
                  Shit is right! it's like the combo of the worst engines BMW has ever made. :(
                  • SELfor50
                    • Jun 2011
                    • 19
                    Thanks everyone, I will use a stock one for now and will spend the proper $$ on a good one later.
                    Cheers of the advice.
                    The comment re 318i engines confused the feck out of me. :|
