ireland enginerign stroker kit
  • Zasz
    • 1030
    I didn't even have to use the search engine to find this info, wow.
    What kind of pistons are we talking about? Would Super-Eta pistons + rods be applicable with M52 B28/S52 B32/M54 B30 crank?
    ///Z
    1988 BMW 325 Super Eta - Elsa
    "i"CONVERSIONWARchip&3.0MAF3.73LSDBBSRSsSMILIES"is"SPOILER+LIPHOUNDSTOOTHSHORTSHIFTERPLASTICBUMPERCONVERSIONEtc.
    Sell Me Your SCHWARZ FENDERS!
    ^ Nothing you post makes any sense.
    • delatlanta1281
      Dart Master
      • Mar 2006
      • 10317
      Go to MM site and read the PDF on m20 motors. Everything you need to start your journey is there. There are many ways to skin this cat, but all the right ways involve time, friends, and money. understand when you go bigger, you are robbing Peter to pay Paul in some aspects. An 885 head wont take to porting and polishing as well as a 323 head will, which adds more to the equation. Do not use super eta pistons if you are wanting NA power, that dog will not hunt. Yes you will save money, but you will have a low copression motor that doesn't build power the way a custom piston'd one will. Save your money, research what you want. You may fine (like many here) that an m50 or s50 swap is the way for you to go and still maintain a low budget.
      I am building my m20 bc I love the motor itself. Yes, it has it's problems, and it is limited, but that sound is magical. Listen to Der Affe, Nando, Mr 325, and most of the other OG's on this topic. They know their shit, and understand the limitations of an M20.
      GL
      Rich
      Yours truly,
      Rich
      you kids get off my lawn.....
      • Zasz
        • 1030
        I also love my M20 to death, but damn custom pistons cost a lot. Alright, I'll do my best to update my build thread when it's in progress.
        ///Z
        • delatlanta1281
          Dart Master
          • Mar 2006
          • 10317
          Dude, Pistons are cheap compared to a fully built head. Research that shit it will blow your mind.
          Yours truly,
          Rich
          • Zasz
            • 1030
            Already on my way to finding a 330 crank and buying MM pistons. If I have the money. What do you mean by 'fully=built'? Machined, ported, with new valves, springs, and rockers? I think you can do that for under $800.
            ///Z
            • The Humjet
              • Jun 2010
              • 528
              A fully built head that we would do to our American v8 heads at work would consist of:
              New valves, re-cut valve seats, new copper valve guide liners, valve guide hone, surface, port and polish with flow bench testing, valve springs, roller rockers and other small bits like stem seals, collets etc.
              Our ohc m20 heads have a bit more parts to replace such as camshaft and lifters. And bmw parts are a bit more expensive than your average 350 Chev or Ford Cleveland
              • delatlanta1281
                Dart Master
                • Mar 2006
                • 10317
                Nope. I mean, I guess you can, but I wouldn't.
                Yours truly,
                Rich
                • digger
                  • Nov 2005
                  • 5917
                  bigger the better with the crank midrange always comes in handy more so than pure topend for street engine. I would not go IE kit , firstly the pistons are flat tops which don't go aswell with the 885 head. BMW didn't redesign the B25 pistons and chamber for fun. The best option for pistons IMO is JE for 885 head as they can do the proper squish , others like CP might also be able if you supply a piston. If you use a smaller crank 81mm or 84mm you can utilise the stock pistons.
                  MM pistons are better but also don't seem suited to the 885 as well as they could.
                  You could also use flat tops with the 731 but it requires much more port work to be worthwhile.
                    • 34827
                    Originally posted by The Humjet
                    There is an Aussie member here called Digger. He has a 3.1 m20 and is pushing 164rwkw which is roughly 220whp. I'm not sure if he got the IE stroker kit. Hopefully he could chime in on this thread he knows what he is talking about when it comes to power upgrades for an m20.
                    He built his own wthMM 86mm 11:1 pistons.
                    A well built head for $800? You're dreaming. A good cam alone is $400-600. $200-300 for good rocker arms (IE hd rockers are actually good), you're at $800 before you've bought anything else, done any machining, port work, or assembly. $800 might get you a rebuilt stock head with only the most worn parts replaced, but its not what you'd put ont a 3.1 bottom end.
                    Pistons are big ticket, but they're not the biggest expense. Its easy to spend $1200 on dyno time alone.
                    • backwoodsE30
                      • 122
                      $3100 for my head from VAC motorsports.
                      alcoholics do it till you barf
                      • digger
                        • Nov 2005
                        • 5917
                        get it independantly flow tested for the benefit of the community?
                        Obviously flow numbers dont mean everything but you do need a certain amount of flow to make a certain amount of hp and it would be good to see what they are able to do.
                        • acolella76
                          • 2950
                          IIRC when I rebuilt my head it fell short a little shy of $850... but that didn't include porting. And to be fair, I pinched every penny. Got a brand new 272˚ cam for $80.
                          -Alex
                          • digger
                            • Nov 2005
                            • 5917
                            i got a $300 port job here in Oz which was very reasonable. Obvioulsy parts are extra but you may not need a whole lot deopending on what you start with
                            • ZM Blue Devil
                              • Dec 2006
                              • 13836
                              we have gotten a few of the 3.0 sets from IE. No issues, and yes one can piece the items together but one stop shop saves time and headaches down the road.
                              For my touring we are in the process of building a m20 3.0 with itbs using IE internals. Should be a fun ride.
                              Levent
                              %20levent@gutenparts.com
                              Ladies:
                              • acolella76
                                • 2950
                                Just be sure not to use the IE front crank spacer. They do not seal
                                -Alex
