HD Rocker Arms
  • jules325i
    • Jul 2011
    • 353
    HD Rocker Arms
    Do i need Heavy duty rocker arms.
    I don't care about money if it gives me peice of mind.
    SETUP
    • 272 schrick cam
    • Uprated Valve springs
    329i
  • Hey_You
    • Nov 2009
    • 963
    I'm gonna use stock rocker arms with my build...but I'm building a m10. For peace of mind though, nothing beats upgraded/overkill parts! Maybe someone who has built an m20 like yours can chime in.
    85' 318i ~The Bronze Bomber (FrankenM10 with a Forced Future :wgaf:)
    • SkiFree
      • Jun 2011
      • 2766
      This has been covered at length before, I think if you searched you'd find a lot of information regarding HD rockers.
      For one to tell you if you need them or not? Frankly you'll have people that will tell you no and others that will tell you yes. Search for the most information you can find, then make the decision.
      On another note why are you running uprated springs with a 272?
      Hey_You - a Little M10 rocker information was just discussed here .... http://www.bmw2002faq.com/component/...opic/t,366046/
      ADAMS Autosport
      • jules325i
        • Jul 2011
        • 353
        My engineer recomended it and the spring tension on my springs are a sligtht increase,
        329i
        • Irish1
          • Mar 2005
          • 279
          Shant and Mr325 recommended HD IE Rocker Arms when they built my great SuperETA/325i 2.7i and I agreed. Even if this car NEVER sees the Track I think it's a smart investment. As soon as I get the funds to have RyanGMW do the GC Coilover install it WILL hit the track, and I'll not have to worry about stressing the ValveTrain. I think it's a good idea, as well as upgraded valve springs.
          • ROLLingKING
            • Apr 2011
            • 1169
            i say yes. why not!?
            while your in there do it once and do it right.the sight even says they are more heavy duty in the specific area where M20 rockers snap.
            I look at it this way. stock rocker arms are built for stock cam and springs. pretty much
            Im getting HD ones cause i drift which involves constant higher RPM's and temps. Ive also been looking at the VAC springs. they cost a bit more but peace of mind goes a long way. And id rather not be stranded in some lot cause somethin broke at 2am
            And its only a single cam. its a fairly inexpensive motor to work with. GO FOR IT
            m20 is plenty. im simply a drifter.
            build thread -- http://www.r3vlimited.com/board/showthread.php?t=206510
            • jules325i
              • Jul 2011
              • 353
              I will Cheers ^
              329i
                • 37833
                I'm running the IE HD rockers in my boosted 2.7 M20. To me it was worth the investment, I'd rather not pull the cylinder head to replace a broken rocker down the road!
                You can definitely use stock springs with a 272 cam though.
                Grover Beach, California
                BimmerHeads.com
                • TobyB
                  • 5268
                  Only if you rev over stock.
                  There's no point in HD rockers on a car that only goes to 6200.
                  We race them to 6800, and that seems to be about the limit for reliability.
                  At 7200, it's worth it.
                  But springs are actually the really crucial element to high revs...
                  BUT.
                  No, they won't hurt, the Ireland ones are hardly any more expensive, and they're fine units.
                  t
                  • jules325i
                    • Jul 2011
                    • 353
                    I just put my order in for IE Heavy duty rockers cheers guys.
                    329i
