Will I be running rich if I install bigger injectors?
  • bastianshaw
    • Jan 2007
    • 2210
    W a good o2 sensor doesn't the computer adjust the (guess) duty cycle? I mostly wanna run bigger injectors (17.5) because of the "better atomization" and they are newer. I'm running a jc chip. Stock everything else
    • 37833
    You will be fine running those injectors. I like to run them in stock or semi-stick M20 engines. Nice upgrade over the old stockers.
    Grover Beach, California
    BimmerHeads.com
      • 34844
      yes
      • bastianshaw
        • Jan 2007
        • 2210
        So to be clear. 17.5 injectors on a stock motor will have the same a/f as 14.5s. Thanks.
        • HR2L
          • 724
          Yes, the DME will adjust DC for the slightly larger injectors. Your MPG gauge will no longer be accurate, but you shouldn't notice any major effect on your overall/actual MPG. The difference in size is roughly 30cc which isn't much. I have been wanting to do this upgrade myself, but have been lazy and am looking for someone who has a set that is reliable (clean and known working), clean and has new o-rings or they are selling a refurbished/rebuilt set.
          • bastianshaw
            • Jan 2007
            • 2210
            will the OBC mileage readout still be accurate?
              • 34844
              no
              • shiboujin
                • Feb 2006
                • 2791
                Originally posted by nando
                no
                  • 34844
                  how will your OBC mileage be correct?
                  it won't. your duty cycle will change, and the OBC is based off the stock injector size. it works the same way the MPG gauge does.
                  • digger
                    • Nov 2005
                    • 6198
                    whats wrong with the correct injectors? if it aint broke...........
                    • bastianshaw
                      • Jan 2007
                      • 2210
                      just want four pintles
