What is the best intake.
  • jules325i
    • Jul 2011
    • 353
    I have a 2.9 stroker 10.5:1 compression, with 272 schrick cam
    (on engine stand still.)
    I was just wondering what intake to use.
    What is extrude honed intake as seen on IE?
    329i
  • Justin B
    Sikky Nar Nar
    • Mar 2005
    • 4273
    Best? ITB's and standalone. DBilas, or custom sets.
    Something not so wild. EH should help.
    • Justin B
      Sikky Nar Nar
      • Mar 2005
      • 4273
      Something from the M20 wiki actually...
      "-Extrude hone intake: an abrasive clay-like material is fed through the manifold to eliminate imperfections deep inside. Costly and worthwhile only if building larger stroker."
      Basically porting your intake manifold.
      • jules325i
        • Jul 2011
        • 353
        All the itb setups i come across like dblias are way to big.
        And making a custon one is just so time consuming.
        329i
        • Justin B
          Sikky Nar Nar
          • Mar 2005
          • 4273
          Not really. I'm talking about buying DCOE adapter plates for the intake runners (a dbilas part is available but the most expensive of a couple options), then sourcing 3 DCOE style throttle bodies in 35 or 40mm. I am building a 3.1L for my 02, someday, and am looking at the jenvey throttle bodies www.jenvey.co.uk . Add air horns and filters, or actually fab up an airbox with foam, cover in 'glass and melt the foam out with acetone or something. Dbilas and 100% homemade are not the only two options.
          • digger
            • Nov 2005
            • 6161
            that is what i would do aswell...........but to the OP get it running on the standard manifold first
            • Justin B
              Sikky Nar Nar
              • Mar 2005
              • 4273
              Agreed ^
              • jules325i
                • Jul 2011
                • 353
                cheers maybe one day.
                Is the extrude intake good bang for buck.
                329i
                • digger
                  • Nov 2005
                  • 6161
                  leave it standard, then get an extrude hone and do a back to back dyno test so you can tell us.....TOFTT
                  i doubt than a mm or two larger bore is significant enough to warrant $800 or whatever it would cost to get it done and shipped to Oz
