Can tty bolts be replaced with non-tty
  • OldSkoolE3
    • Feb 2011
    • 137
    Pretty much what the title says. Anyone replace tty head or rod bolts with grade 8 or higher metric bolts??
  • Wh33lhop
    • 11705
    CAN they be? Sure. Would I do it? No. This is an instance in which they are that way for a good reason. Take the care and time to find the proper hardware and do it right.
    paint sucks
    • OldSkoolE3
      • Feb 2011
      • 137
      I dont see spending 8$ a bolt on tty if i can use a standard bolt. Stretching a bolt with a dial gauge doesnt seem as consistant as torquing it. Maybe its just my background in engine building.
      • lolcantturn
        • 4588
        Are you bloody well out of your mind? These are bolts that hold fucking 180PSI together under an explosion, you better fucking hope to pay $8 a bolt.
        Originally posted by TSI
        OEM+
        • Jafxod
          • May 2011
          • 1301
          I mean or you could also try drywall screws.
          Go buy a honda.
          • OldSkoolE3
            • Feb 2011
            • 137
            Well then ill spend 40 dollars a rod and stud them... this is just stupid. Im not gonna spend 8$ a bolt just to throw them away in 12 months when the motor comes back apart.
            • Justin B
              Sikky Nar Nar
              • Mar 2005
              • 4273
              A whole stock headbolt set is less than 30 bucks, quitcherbitchin', or upgrade to ARP studs or something and spend 10x the price of a head bolt kit.
              OR
              http://www.ebay.com/itm/BMW-M20-ARP-...328#vi-content
              Hmm, I'd go with stock if you're not boosted. It's less money than a tank of gas.
              • OldSkoolE3
                • Feb 2011
                • 137
                I am boosted and it isnt a street car. I tear the motor down at the end off the season to look things over and replace gaskets and bearings if need be. Sounds like studs are going to be worth it in the long run...
                • OldSkoolE3
                  • Feb 2011
                  • 137
                  gasket failure caused by inferior OEM head-bolt stretch.
                  This is the #1 cause of premature head gasket failure, especially on boosted or high output engines. Right from arp's site!
                  Vac sells arp rod bolts for 16$ ea.... that pays for its self after one rebuild...
                  • Dj Buttchug
                    • Jun 2010
                    • 7686
                    invest in arp hardware. they can be re used several times and they are proven
                    end thread
                    Turbo M42 Build Thread :Here
                    Ig:ryno_pzk
                    I like the tuna here.
                    Originally posted by lambo
                    • Justin B
                      Sikky Nar Nar
                      • Mar 2005
                      • 4273
                      I agree then, I'd upgrade to the ARP stuff especially with your application.
                        • 37833
                        ARP all the way.
                        Grover Beach, California
                        BimmerHeads.com
