Why so close?
  • jules325i
    • Jul 2011
    • 353
    Why so close?
    Put my head together today and found that cylinder 2 inlet rocker pad was quite offset on the camshaft lobe.
    the rocker adjusting roller is central on the valve stem.
    Everything is installed correctly.
    Does this mean the cam is maybe ground wrong.
    Parts:
    Schrick 272
    IE heavy duty rockers
    OEM everything else.
    329i
  • Cabriolet
    • 9620
    it looks like you did not fully seat the cam. or the seal that holds the came in inst set fully
    Much wow
    I hate 4 doors
    • jules325i
      • Jul 2011
      • 353
      Yes i thought that too.
      But i know that it is fully seated.
      And number 2 inlet is the only one offset.
      329i
        • 34847
        are the rocker shafts locked in place with the key?
        anyway, the way it looks doesn't seem like there's really a problem.
        • jules325i
          • Jul 2011
          • 353
          Yes
          329i
          • jules325i
            • Jul 2011
            • 353
            Has anyone else encountered this with a schtick cam.
            329i
              The entire bearing surface of the rocker is on the came, therefore there is no problem with its position.
