broken timing belt
  • Exodus_2pt0
    • 5943
    That one hit looks dangerous... I'd be concerned about the integrity of the ring-land
    No E30 Club
    • JGE30
      • 104
      how so?
      • TurboJake
        • 3780
        That first picture would concern me. That's more than close enough to the edge to possibly damage the ring lands, but I'm willing the bet the piston is also out of round.
        The second little ding should be fine, but you might as well get a new set now thanks to the first one.
        Leave Me Transaction Feedback
        • JGE30
          • 104
          Thats the only one with that.
          i am going to rebuild the head would it be a big risk to jest leave it?
          • Kershaw
            • 11822
            the pistons will be fine.
            AWD > RWD
            • Exodus_2pt0
              • 5943
              SHOULD be fine.
              How expensive is a piston to throw in there? Vs. possibly having to do the entire job again.
              OP, I would at the very least pull that piston out and inspect it very well. It just is not worth the risk to have that thing crack on you and possibly take out the head you are having repaired with pieces of piston.
              Seriously, how can anyone say for sure that it will be fine just from a picture? That piston is not just nicked, it got smashed.
              No E30 Club
              • JGE30
                • 104
                So jest change that piston then?
                  • 37834
                  I'd run it as-is.
                  Grover Beach, California
                  BimmerHeads.com
                  • JGE30
                    • 104
                    cool
                    • cabriodster87
                      • Jan 2011
                      • 1042
                      I concur, piston material is most likely displaced. As well as the piston may have been weakened from the shock. I would be afraid to use it, might fail under high rev, pressure. Get rid of it and sleep without worriment.
                      Reich und Roll!
                      • JGE30
                        • 104
                        Any one know a good machine shop in the 95127 area?
                        • JGE30
                          • 104
                          bump
