m20 Timing belt Crankshaft Gear Removal
  • downforce22
    • Aug 2009
    • 3193
    I noticed some broken teeth on the timing belt driven gear that turns the crankshaft. I managed to find one in the junkyard but have no clue how to remove it. Any ideas on how to take it off? I have heard it is torqued between 120-300 ft lbs, but I don't know if it is reverse threaded or not. Any ideas?
    Thanks, here is what mine looks like and why it needs to be replaced:
  • Cabriolet
    • 9620
    its torqued to 500ft-lb
    we made a tool to break it loose.
    Much wow
    I hate 4 doors
    • Jafxod
      • May 2011
      • 1301
      holy mother fuck
      • downforce22
        • Aug 2009
        • 3193
        Looks cool cabriolet, but how do you keep the crank from spinning? I've heard a screw driver is not strong enough to hold it.
        • dnguyen1963
          • Nov 2011
          • 2651
          Have you not noted the bed frame he used to hold the shaft?
          • BrownBeanE30
            • 965
            lol damn thats crazy
            Originally posted by InuFaye
            silver is old man color car. you need dat BRO-SECA BLUE.
            so true.. never let them know where you live..I almost ended up in jail when I was raping young women on craigslist
            An S5x is like the girl you want to marry - an m30 is the girl you don't bring home to mom.
            • acolella76
              • 2950
              Well unless your screwdriver can break something free that was torqued to 308 ft/lbs, no. A screw driver is in fact not strong enough to hold it.
              Relevant thread: http://www.e30tech.com/forum/showthread.php?t=101385
              -Alex
              • paperplane94
                • Jul 2011
                • 420
                The pic in that thread always cracks me up for some reason, ill be lauging until I have to do it myself...:razz:
                • acolella76
                  • 2950
                  So does that timing gear just slide right off? I have seen some people need to use pullers to get the damn things off.
                  -Alex
                  • digger
                    • Nov 2005
                    • 6206
                    remove the bolt and thick washer and screw the bolt partially back into the crank nose. Then get some decent thick plate drill holes the same spacing of the drilled and tapped holes on the gear and get some long bolts and screw them into the gear with the plate resting on the end of the bolt and use the bolts to pull it off. clear as mud?
                    • downforce22
                      • Aug 2009
                      • 3193
                      Well I sprayed liquid wrench on it for a few days and knocked it with hammer a couple times before spraying it and letting it soak over night. The electric impact did the job. For future reference the bolt is not reverse threaded and I didn't need a puller to get the old one off. Here is the old one, sheared all the way around. The PO had to see it because there were no metal shavings in the tray under the gear.
                      • Exodus_2pt0
                        • 5943
                        How the hell???
                        No E30 Club
                        • acolella76
                          • 2950
                          Just tackled this this weekend.
                          Here is my OE-ish crank holder.
                          Also didn't need a puller to get that front gear off either... just got a prybar and it came off with ease
                          -Alex
                          • BimrFett
                            • Jul 2017
                            • 42
                            Here's hoping you are right!!!!:coolphoto:
                            • BimrFett
                              • Jul 2017
                              • 42
                              But seriously. I can't thank you enough!!!!!!
