2.8L M20 build - Now with 2.7L!
  • 325e10
    • 161
    #166
    hurry up damnit
    • acolella76
      • 2950
      #167
      you shut yer got damn mouth now boy
      -Alex
      • acolella76
        • 2950
        #168
        Got the block and everything back from the machine shop! Had the block shaved .080" (2.032 mm) and honed. They even cleaned and painted the block for me. It looks fucking good, I dont even want to put it together now.
        Plastigage'd the main and rod bearings and everything is dead nuts. Went to install everything and I forgot the assembly lube and ring compressor at a friend's house! Will update with pictures tonight or tomorrow!
        -Alex
        • Simple_Smith
          • Aug 2011
          • 585
          #169
          Pics or it didn't happen! haha glad to hear you're still truckin
          1989 JDM-Tech 2
          2010 335 D for daily
          • Delraco
            • Jul 2010
            • 116
            #170
            This is good news. In for pics
            • ForcedFirebird
              • Feb 2007
              • 8300
              #171
              Check valve to piston clearance.
              john@m20guru.com
              Links:
              • acolella76
                • 2950
                #172
                Valve clearance should be fine, it is only sitting 0.042mm closer to the deck than the 2.8 motor, which had plenty of clearance.
                -Alex
                • ForcedFirebird
                  • Feb 2007
                  • 8300
                  #173
                  don't assume anything.
                  It makes an ASS out of U and ME.
                  "Supposedly" I was safe on the eta pistons to take .025" off a head with .080" VTP clearance. I took .015" off the head and .020" off the head gasket and my valves are making a racket.
                  john@m20guru.com
                  Links:
                  • SkiFree
                    • Jun 2011
                    • 2766
                    #174
                    I cannot agree more, break out the putty. Looking forward to hearing this thing run properly.
                    ADAMS Autosport
                    • Simple_Smith
                      • Aug 2011
                      • 585
                      #175
                      Putty, play doh, tootsie rolls, whatever it takes
                      1989 JDM-Tech 2
                      • Massimo
                        • Jan 2008
                        • 3207
                        #176
                        Didn't Xworks have a method that didn't require removing the head.
                        • acolella76
                          • 2950
                          #177
                          Checked VTP clearance and all is well in the world. .093" with the head gasket uncompressed which should be plenty, no?
                          Assembled the motor and everything, primed the oil pump, and the oil is frothy... is that bad? And if it is how should I fix that?
                          Piston deck height:
                          So beautiful
                          Can you tell I had an exhaust leak :rofl:
                          -Alex
                          • ForcedFirebird
                            • Feb 2007
                            • 8300
                            #178
                            Stock gasket?
                            john@m20guru.com
                            Links:
                            • acolella76
                              • 2950
                              #179
                              Yeah, went back to stock gasket. Even with the copper spray the MLS gasket was still giving me some trouble.
                              So frothy oil... bad? Change the oil?
                              -Alex
                              • acolella76
                                • 2950
                                #180
                                The motor won't start! It will turn over like it wants to start and will kind of stumble a little bit like it is about to start, but never actually does.
                                -Getting spark at the plugs
                                -REEKS of fuel, so I'm assuming there is fuel.
                                -Timed properly.
                                What do?
                                -Alex
