If there's fuel and spark, check for compression. That'd be step 1 in my book.
2.8L M20 build - Now with 2.7L!
Bump! I need help!
-Getting 3bar fuel at the fuel rail
-Getting 12v at the injectors
-Injectors are showing 14.7ohm resistance
-Sparking at the plugs
-Plugs, cap, rotor all clean and good
-Timed correctly
It will only start with the throttle wide open. What could this mean? Bad TPS, not getting enough air, getting too much fuel... ?-AlexComment
what CEL's do you have?OBD1 M54/M52TU swap as a M50b25
None, it is throwing no codes!
Also, forgot to mention this, but with the intake boot and everything off it will actually run. Of course I have to hold the throttle open cause of all the unmetered air, but it doesn't need the starter to be engaged. Even still... it has to be WOT just to start. Doesn't really make sense to me.-AlexComment
Highly likely.
Turn the key on and hold the IAC, is it "buzzing"?
Mine just went out on me on Friday, had to use the throttle cable to hang it open a bit for my car to run until the new one gets here. Sucks, I have about 5-6 straight IAC's on the shelf and my boot requires the 90* IAC, FTL.Comment
Highly likely.
If your referring to me the icv is working. if you have any ideas my thread is here.
sorry im not trying to thread jack
but yeah id check your idle control valve, tps, and if you have one your cold start injector.Comment
It buzzes when it's on and the little toy inside moves freely, so it's definitely working!
I am thinking about trying out another ECU, and if that doesn't work I will probably give up and take it to a shop.-AlexComment
perhaps there is a vacuum leak on the bizzach tube, intake manifold or TB?OBD1 M54/M52TU swap as a M50b25
Code reader didn't show any codes for the TPS. I floored your mom.
Oh? I didn't know I was able to do that. I used a code reader to see if I have any codes, so I'm not sure if the Ostrich will be able to show much more?-AlexComment
