It's happened again:(
  • camip
    • Nov 2011
    • 1253
    I have a 1985 325e and its happens about once a month the car will be running fine then I'll go to start it and it turns over fine but won't fire. Yes it has gas. Any ideas on where I should start to trouble shoot.
  • LJ851
    • 7918
    What happens if you step on the gas when this happens?
    Lorin
    The M30 is God's engine.
    • camip
      • Nov 2011
      • 1253
      Nothing
      • Dj Buttchug
        • Jun 2010
        • 7659
        spark?
        Turbo M42 Build Thread :Here
        Ig:ryno_pzk
        I like the tuna here.
        Originally posted by lambo
        • camip
          • Nov 2011
          • 1253
          Checking spark as we speak.
          • Dj Buttchug
            • Jun 2010
            • 7659
            if its intermittent might check the coil as well...
            Ig:ryno_pzk
            • camip
              • Nov 2011
              • 1253
              She has spark.
              • McGyver
                • 4573
                do you have fuel at the rail? (is your pump dieing?) or your filter super clogged?
                • Dj Buttchug
                  • Jun 2010
                  • 7659
                  k so we got fuel and spark. and im assuming its in time correct?
                  Ig:ryno_pzk
                  • LJ851
                    • 7918
                    IAC valve is a possibility.
                    Lorin
                    • camip
                      • Nov 2011
                      • 1253
                      Yes timing is correct I was driving it fine earlier today. I will look into the fuel at rail how do i check this?
                      • Dj Buttchug
                        • Jun 2010
                        • 7659
                        im thinking you dont have fuel... key on engine off and see if you can hear the fuel pump prime.
                        yank a fuel line and see if you in fact have fuel.
                        if you do then go from their. id check injector pulse next.
                        Ig:ryno_pzk
                        • camip
                          • Nov 2011
                          • 1253
                          Fuel in lines after fuel pump car now will fire but then die.
                          • delatlanta1281
                            Dart Master
                            • Mar 2006
                            • 10317
                            Hmm You still need to see if the fuel pump is getting good power. Also, relays can be going bad as well. No CEL?
                            Yours truly,
                            Rich
                            you kids get off my lawn.....
                            • long tall eta
                              • Jul 2010
                              • 1536
                              no cel in an 85e
                              cps??
