I think my ECU may be bad, HELP!
  • John West
    • 4
    Car is coming up with these codes:
    03 Fuel pump relay, 15 Fault lamp, 17 Injector valves (Cyl 2,4,6), 28 O2 sensor circuit, 10 O2 sensor control, 05 Tank venting system, 16 Injector valves (Cyl 1,3,5).
    Had been spratically been coming up with an O2 sensor code and a EKT circuit for years but now I appear to be haveing a major failure. Any ideas? The only thing I can think that could effect that many things at once is the ECU. Any help would be greatly appreciated.
  • 10Toes
    Me Father Was A Tree
    • Jan 2008
    • 61222
    What car is this?
    • Kershaw
      • 11822
      most likely a ford fusion.
      AWD > RWD
      • John West
        • 4
        Originally posted by nwvb bmw
        What car is this?
        1990 325i Convertable.
        • TurboJake
          • 3780
          That many codes, Yeah. Replace the ECU.
          Especially if it's putting those numbers out. There are no 2 digit codes. And there are no codes that are a 120X. The lowest one is 1211
          In fact. I'm really curious as to how you got to those as the numbers, and associated them with faults..
          Find information, resources and relevant links for e30world.com. This domain may be for sale.
          Leave Me Transaction Feedback
          • TobyB
            • 5296
            Peake only has 2 digits... right?
            t
            • apbt_rescue
              • Jan 2011
              • 19
              yeah, he is taking those fault codes from the Peake tool.
              1991 325iX
              • John West
                • 4
                http://e30world.com/fuel/BMW-E30-DME...ic-fault-codes
                I am using my old Snap-On brick to get the codes but also have a new Launch scanner that gives me the same numbers. Found a used ECU for $125. Gonna try that and see if my problems go away. Thanks for the help.
                Log into Facebook to start sharing and connecting with your friends, family, and people you know.
                • paperplane94
                  • Jul 2011
                  • 420
                  How about the good 'ol stomp test? No bricks about it.
