Trying to do some research on these.
I'd really like to hear from anyone that is running a turbo set up. And i'm not really interested in a bolt-on set up, but a true rebuild.
Where did you get your internals from?
Where did you get you get your turbo kit from?
What kind of boost pressure and compression ratio are you running?
What kind of a ECU are you running/will a WAR chip work?
Also, what's the cost of a build like this? I'm trying to get a reliable 250HP from an M20, is it possible?
Thanks
Thanks
