Is Harness/Ecu on Eta engine???
  • darvo
    • Dec 2010
    • 407
    I have an early 325e that I will convert to I on some time. I have a spare 2.7 block to make a stroker I.
    I just bought and have a Custom Motronic with Ms3 board, Is wiring harness and crank wheel.
    Can I use this on my Full Eta engine and program it. Until I complete the "IS" Stroker engine for turbo?
  • TurboJake
    • 3780
    No. You will need to swap over all of the I parts and complete the stroker build to run it. The harness connectors at the ECU are very different between the ETA and I DME's
    027 DME
    153/173/380 etc (M1.1 and M1.3) DME
    Leave Me Transaction Feedback
    • darvo
      • Dec 2010
      • 407
      My complete harness, Ecu and Crank wheel are from an "IS" car.
      What other connector changes?
        • 37833
        You can run it, sure. Set the rev limiter low (5000) and you'll be fine.
        You'll need to swap the i ICV setup on there though.
        Grover Beach, California
        BimmerHeads.com
        • darvo
          • Dec 2010
          • 407
          So im better off swaping the IM as well?
            • 34844
            since it's MS3, it doesn't care what type of motor you have. it'll run basically anything, but with the eta the only caveat is the 120-tooth flywheel sensor isn't supported, you'll definitely need the 60-2 wheel and sensor from an M20b25. which you've already got.
            MS3 will also run the eta's ICV but if you've already got the I stuff, use it, it's better. as far as the intake manifold - it doesn't really matter.
            • darvo
              • Dec 2010
              • 407
              Thnks for the reply! I just dont want to wait until I refresh the stroker I... To use the Ms3, So I should set a really low rev limiter? 5k to 5,4?
                • 34844
                set it to what the eta can handle, so yes.
                  • 37833
                  But he mentioned the MS is built in to a Motronic case so most likely it's a PnP kind of setup which means he's going to want to use the i harness with it. This means he'll want the i ICV since it will plug in!
                  BimmerHeads.com
                    • 34844
                    it's MS3. not exactly the same as an MS2 pnp. no extra hardware needed for an ICV (2 or 3 wire). I'm not saying he shouldn't use the "i" ICV, I'm just saying MS3 doesn't really care.
                    I don't know why you'd build an MS3 PnP for a 55 pin harness anway. you wouldn't be able to do sequential injector or COP, the biggest benefits of MS3..
