Miller MAF 19# Injectors
  • smooth
    • Apr 2005
    • 1940
    Thanks for the responses.
    blocke,
    will you post your last few smog results, please, and indicate when the new cat was installed and then the test that reflects the Miller system?
    Das ist nicht nur nicht richtig, es ist nicht einmal falsch!
    • blocke
      • 1305
      Here ya go:
      I don't have a scan of the 3rd test that was run with the maf on, but it passed.
      It wouldn't affect your numbers, it's just a visual thing.
      Parts Wanted
      The Never-ending Resto Mod
      • smooth
        • Apr 2005
        • 1940
        Originally posted by blocke
        Here ya go:
        Thank you, blocke. It's good to see we're still using 767 NOx, too. I'm sitting at 766 so trying to get that figured out before I make any changes :|
        • blocke
          • 1305
          New cat VS a 20 year old cat does wonders. Better do it at some point anyway, Cali smog laws are only getting tighter so that they can get old cars off the roads. A new cat will at least keep you in the game longer than our OE ones.
          Parts Wanted
          • smooth
            • Apr 2005
            • 1940
            That number was last year, two years after the new cat.
              • 37829
              Except you have a better chance of passing with a GOOD original cat than one of these garbage replacement cats that exhaust shops are throwing on cars these days. The cheapo replacements are only good for the first smog test most of the time.
              Classic BMW Specialists
              Grover Beach, CA
              www.BimmerHeads.com
              • bastianshaw
                • Jan 2007
                • 2210
                word
                • smooth
                  • Apr 2005
                  • 1940
                  How much should one expect to pay for a decent aftermarket cat? Or do any exist?
                  • Robert
                    • Dec 2010
                    • 3770
                    I have come back with some news.
                    Just installed my 19lb injectors and maf. I couldn't be any happier. Throttle response is amazing. Idk if its in my head, but i feel like my car has a little more power top end.
                    I do recommend this to anyone.
                    Also ,
                    If you plan on doing this, change your fuel filter & fuel lines. I did all to make sure the car doesn't run lean with this chip. It helped a lot too.
                      • 37829
                      Fuel filter and fuel lines are maintenance items. ;) They should be done as needed, regardless.
                      Grover Beach, CA
                      www.BimmerHeads.com
                      • BMW_325i
                        • 61
                        Also ,
                        Do you have an AFR guage, and did the larger injectors need any change in fuel pressure to meet the 19lb flow rate?
                        1988 Lachssilber E30 325i sedan.
                        Factory fit-out: manual; SILBER LEDER; M SPORT SUSPENSION.
                        Modifications so far: Miller MAF + 19# ECU; Ford 19# Design 3 injectors; IE adjustable FPR; KAMotors CF airbox; IM MTX-L; EBC Greenstuff.
                        Retired - '83 Arctic Blue E28 528i powered by M30B32
                        • Robert
                          • Dec 2010
                          • 3770
                          Nope, I don't have a AFR
                          It runs perfect with rebuilt injectors , fuel filter and fuel lines.
