Improving a 325e
    • 37828
    Originally posted by Jacksontheogre
    I guess the only advantage is thats if i just switch to an "i" top half i don't have to worry about swapping all of the transmission components as well. On the other hand it seem like the 24v swap is where the power is at unless your do forced induction which i understand is about $2500 by itself. I'm headed out to a euro salvage yard to see what i can come up with...anyother types of motor i could possibly look out for?
    Doing an M50 swap is seriously not worth the cost and time. The people that say it is are just fooling themselves. You should either do the i head swap, swap in a complete i engine, or go straight for the S50/S52 engine swap.
    Originally posted by camip
    I've heard mixed results on the 325i head swap I've been contemplating it.
    The head swap makes better power than R3V says it does. If you've got a nice head with porting and a cam (like the ones I sell) you WILL make enough power to be happy. An important part of doing this conversion is swapping the diff for a 3.73 so it acts more like an i car.
    Originally posted by squidmaster
    chip it, drive around, get 27-35mpg, be faster than civics, and save for an m50. I was going to do a 2.7i stroker as well, but after reading a lot it seems that an m50 swap would be cheaper and yield better results. just an opinion though!
    There is absolutely no way that a 24v swap will be cheaper than a head swap on the M20.
    Classic BMW Specialists
    Grover Beach, CA
    www.BimmerHeads.com
    • squidmaster
      • Aug 2011
      • 2666
      from what I've seen it'd be cheaper to make the target hp than doing a stroker, and then moding it even more to be equivocal to an m50.
        • 37828
        My replies on this forum are based on real life though, not things I have read online. ;)
        Grover Beach, CA
        www.BimmerHeads.com
        • squidmaster
          • Aug 2011
          • 2666
          of course! I'm only speculating. And from reading other people's costs that have been reasonable.
          Then, would it actually be cheaper to do a stroker build and mod it to make equal power to the m50?
          • camip
            • Nov 2011
            • 1253
            Originally posted by MR 325
            The head swap makes better power than R3V says it does. If you've got a nice head with porting and a cam (like the ones I sell) you WILL make enough power to be happy. An important part of doing this conversion is swapping the diff for a 3.73 so it acts more like an i car..
            I'm actually in love with your heads and decided if I do this swap i want it done the best I can then realized I'm still in college and I'd be a dumbass to spend money on a new head etc. when my car runs fine. I think I'm just going to slowly collect the pieces I need and do it after I finish school.
            • Bearmw
              • 1323
              The most sensible decision I've seen in a long time.
              • Arems87e
                • May 2008
                • 102
                MR 325 is absolutely correct on this. I also have a 325e and did a head swap. I swapped the head with a 731 casting head (which is direct match to e bottom) 3.73 LSD and with of modifications here and there, couldn't be more happier with my car.
                So I'll say do a head swap or other wise go straight for a S5X...M50 swap is not less expensive than a head swap.
                • PeteD
                  • 982
                  Where are you in NE? I can appreciate modded etas!
                  • Arems87e
                    • May 2008
                    • 102
                    I'm in Marlboro, MA. Yea absolutely you could come check it out
