IE silicone coolant hoses
    • 37833
    Who's running the IE silicone coolant hoses on their late model cooling system?
    Thoughts and opinions please!
    Grover Beach, California
    BimmerHeads.com
  • whodwho
    • Jun 2008
    • 1547
    I have a full set plus the spider hose but have not installed them yet, look to be nicely made.
    My M20 Frankenbuild(s)
    4 Sale - Fully Built TurnKey Megasquirt Plug and Play EMS
    • Cabriolet
      • 9620
      Matt,
      My close friend is running them. they don't seal exactly as well as rubber ones. noticed an issue where the thermostat housing had the usual pitting and water was seeping past. after replacing that output flange, been great for 8+ months. they dont look OE so when i replaced mine i went rubber.
      Much wow
      I hate 4 doors
        • 34844
        I can't see any possible reason this would be wortwhile?
        • Luis325
          • 3847
          I had them in my m20 any fit nice and never had any problems...
          Bough the same for my s50 e30...
          Supposedly they dont expand as much as rubber ones under heat ?????
          1986 "C2 2.7 Alpina" Sedan
          1987 325ic Black Vert
          • whodwho
            • Jun 2008
            • 1547
            They were about the same price as Pelican wants for a hose set (IE's 15% off day) and will probably outlast the car. They are impervious to oil and stock ones can delaminate and bulge under heat.
              • 37833
              Exactly my thoughts. I want to replace all of the hoses on the turbo E30 and the silicone hoses aren't much more in cost and I assume they'd be better longevity-wise.
              BimmerHeads.com
              • smooth
                • Apr 2005
                • 1940
                (IE's 15% off day)
                Is this a coupon code or something I missed or something that happens every so often?
                I need to replace a few of my hoses. Main one I need is the expensive expansion tank hose :(
                are you guys going with blue or black?
                Das ist nicht nur nicht richtig, es ist nicht einmal falsch!
                • whodwho
                  • Jun 2008
                  • 1547
                  They don't do the discount action much, this was a black friday sale
                  I went with the black ones 'cause it's not a race car' (To play along with a recent r3v phrase) :)
                  • smooth
                    • Apr 2005
                    • 1940
                    ah crap hopefully my coolant hose lasts me until next sale
                    the end was disintegrating so I cut it down. but it's bell shaped normally so I had to heat it up in a pot of water and smash a glass down inside then run outside and mash it over the housing before it contracted again. seems to be holding up so far (knock on wood) :D
                    ('cept yours *is* a race car, heh)
                    • ak-
                      • 12422
                      Me. They sure are stiffer than rubber and will for sure outlast.
                      Near the thermostat housing, though, it's formning a crustation of dry coolant that seemed to be seeping a bit. I didn't buy them new though; it's second hand.
                      I dig them. My runner ones were flappy and soft.
                      1991 325iS turbo
