What's the recipe for a more badass M20?
  • Chubtone
    • Feb 2012
    • 66
    I'm not talking about forced induction or going crazy with money as no object. I want to keep it naturally aspirated. I'm not trying to stay within the rules of a particular class. Just build a hot street motor that will be reliable and fun enough for track days. What can you do in the $3-4k range? Thanks
  • smooth
    • Apr 2005
    • 1940
    Talk to Robert over at http://www.e30motorwerks.com
    Das ist nicht nur nicht richtig, es ist nicht einmal falsch!
    • Rsully70sev
      • 2391
      S5x
      M5x
      M20's are awesome motors, but can only go sooo far NA.
      • ALYKZANDYR
        • Sep 2009
        • 1336
        reading r3v for a while now and from what i have read the only way to get good performance out of an M20 is a full rebuild, longer stroke, new ecu, and going turbo with "i" cyl head.
        • OniKyan
          • Sep 2011
          • 671
          Originally posted by Rsully70sev
          S5x
          M5x
          Not relevant to thread.
          OP, for 3-4k you could do a decent build.
          2.7, or 2.8, headwork, cam, Megasquirt/AFM delete, headers, exhaust and freshen everything up while you're in there.
          M20B23 Euro 323i - The Legend Of Ron Burgundrot
          • deutschman
            • May 2008
            • 5958
            Can you do any of the work your self? If so what are you comfortable doing by your self? The more money you pay some one ells to do work for you the less you can spend on the motor. Do a "stroker" motor with an "e" bottom end and and "i" head. Have the bottom end rebuilt with OE components. Have the head rebuilt and have the machinist do a three angle valve job (30/45/62 intake, and 30/45/ 60 exhasut). Get a 272 cam (you wont have to machine the pistons or get over size eccentrics). Try and port match the intake and intake runners, and exhaust runners and exhaust. Get some good headers, 19lb injectors, fuel regulator, and m30 AFM. You should be able to do all that with your budget and maybe even still have some money left over to play with.
            You can also talk to Andrew over at Ireland Engineering, or some one at Groma race Fabrication.
            • dashboardmonkey
              FUCK YOUR WAFFLES
              • Jun 2008
              • 6158
              Cam, injectors, m30 afm and chip. Or turbo
              -Andy
              • 323iNathan
                • 232
                I'd go with new gaskets/seals, chip, MAF/CAI, headers + catback, cam + adjustable cam gear (apparently the 284/272 schrick works nicely).
                Keeping it NA I'd say the next step from there would be 2.7, 2.8 or 3.0L stroker.
                  • 37829
                  Buy one of my cylinder heads of course!
                  Classic BMW Specialists
                  Grover Beach, CA
                  www.BimmerHeads.com
                  • acolella76
                    • 2950
                    3.2L stroker with Metric Mechanic pistons, MR.325 cylinder head 288 cam, extrude hone intake manifold, big bore throttle body, long tube headers, Megasquirt for wasted spark and MAF delete. Just a start...
                    -Alex
                      • 34839
                      for $3-4k - spend it on the cylinder head, long tube headers, and a tune.
                      changing the size of the bottom end doesn't make a huge difference for how much it will cost, not in comparison to the above 3. The main advantage there is more bottom end grunt and a higher CR, but it's really not worth doing less than a 3.1 liter, because they will all end up costing about the same (2.8, 2.9 etc). But by that time you've probably spent twice your $4k budget with the required supporting mods (stock intake manifold/TB isn't going to help on a 3.1 with good exhaust and a worked head).
                        • 34839
                        a motor like this would cost $4k, but not really make a lot more power than stock.
                        2.7i's are best for turbos, N/A they're pretty "meh".
                        with $4k, he could do a LOT better than 19# injectors, FPR, and M30 AFM.. a basic miller MAF kit would be a better deal and likely perform better. adjustable FPRs are mostly pointless if you're N/A.
