Wierd shake/vibration/clunking?!
  • blck325is
    • Apr 2006
    • 1749
    Hey guys, my car has been having some shuddering/shaking pretty strong at around 60mph. The steering wheel stays pretty straight but it moves side to side once the car starts shaking.
    I have a good guibo, my csb just got replaced, and my tires were recently balanced. My question is whether the transmission might be the problem now because I can't think of anything else.
    Originally posted by csermonet47
    Vlad, you are handling this quite unprofessionally.
    Also, you are a cock with tacky taste.
    That is all.
  • Keith M
    • 2338
    Half shafts, driveline, steering rack or other front suspension parts?
      A vibration that you feel in the steering wheels is from the front suspension. If you feel it only in the seat it is from the rear suspension or drivetrain. Take the car to a shop and have a pro diagnose it.
      • Northern
        I like cupcakes & sh!tboxes
        • 5284
        tire balance or alignment as well.
        Originally posted by priapism
        Originally posted by shameson
        • Stoner Sam23
          • 186
          Bad u-joints have been plaguing me.
          • stamar
            • Apr 2011
            • 1362
            a vibration at a certain speed and above is most likely wheels unbalanced or wheel bearings.
            Driveline would be at a certain rpm.
            • Stoner Sam23
              • 186
              Drivetrain is speed specific vibration. Mine was from 65 to 70. Your driveshaft rotates with your wheels no matter what engine RPM says.
              • EREKSHUN
                • Apr 2011
                • 310
                i had the same thing 60 mph like clock work. it was my control arm. i suggest you change both sides. i didnt and now like clock work 80 mph shakes my dash.
                • bernzpeed
                  • 3917
                  your driveshaft is bent
                  89 E30 S52
                  Transaction Feedback.
                  • blck325is
                    • Apr 2006
                    • 1749
                    Driveshaft was recently replaced.. Gonna get under the car and do some poking around.
                    That is all.
                    • blck325is
                      • Apr 2006
                      • 1749
                      Its the control arms.. the ball joints are positively fucked.
                      That is all.
