External fuel pump delete
  • Davidov
    • 78
    87 325 (e) 4/87 build.
    I have been searching for some info on fitting a single Walbro pump in place of the dual internal/external setup.
    From my understanding I need:
    - In-tank pump
    - Metal fitting to delete the external pump
    Two questions:
    - Which pump will fit the fuel pump carrier, and do I need to modify it to physically fit?
    - Which pump has a good enough flow rate.
    Will this one work?
    http://www.ebay.com/itm/Walbro-Fuel-...sories&vxp=mtr
  • Davidov
    • 78
    Walbro GSS340 is also a TRE340
    • Cabriolet
      • 9620
      my question is why?
      seems like a whole lot of work and hassle for no real benefit.
      Much wow
      I hate 4 doors
      • Davidov
        • 78
        1. I'm getting some long cranking, so I think the in-tank supply pump is going out. So it would need to be replaced either way.
        2. Less components = less points of failure
        3. The walbro is cheaper than factory replacements.
        I thought this was a more common modification? Nobody has some advice?
        • Cabriolet
          • 9620
          on the older style (2 pump cars) the in tank is only a lifter and the pressure comes from the external pump. neither cause long cranking issue. if your pumps are dying you loose power at high rpm or under load.
          as for your #2. that last setup has worked in your car for over 20 years. thats gonna be longer than any "mod" you are planning to do.
          #3 all i have to say. friends dont let friends buy ebay crap mods. R3v hates 99% of ebay crap.
          Paging Jim he has the best list of things to check first.
          most likely the CPS is dying. only when the DME sees that the engine is turning do the fuel pumps turn on.
          Much wow
          I hate 4 doors
          • Davidov
            • 78
            Ok well a fuel pump stamped "walbro" is not ebay crap.
            Even parts store replacement for these cars are expensive.
            A long crank is the least of my worries. A 20 year old fuel pump with unknown mileage is something to be concerned about.
            • Davidov
              • 78
              Cabriolet = no help
              • Cabriolet
                • 9620
                How about instead of being an idiot you do some searching.
                This question has been asked before, and answered the same way.
                http://www.realoem.com/bmw/partgrp.d...id=47308&hg=16
                Unless your pump is making noise you are fine.
                Much wow
                I hate 4 doors
                • Dj Buttchug
                  • Jun 2010
                  • 7678
                  Im all for removing hardware. 1 in tank pump is far better than an in tank feeder pump and a high pressure external.
                  Get yourself a tre340 fuel pump, throw away the external and run new fuel lines. I had issues with an old volvo cutting out in turns/ not starting on hot days. Did a conversion and it fixed all my problems. If youre interested i have a OEM in tank high pressure pump you could use. pm me
                  Turbo M42 Build Thread :Here
                  Ig:ryno_pzk
                  I like the tuna here.
                  Originally posted by lambo
                  • Davidov
                    • 78
                    Neither of those links answer any questions.
                    Ok, here's what I need to know. Why do I need to run new lines?
                    • Davidov
                      • 78
                      I see now that the pump carrier only has to be modified slightly to fit the pickup filter/sock in the tank.
                      Now.
                      1)Does the return line have to be modified?
                      2)I've heard vague informatin on running new lines to the tank? Why and how?
                      • TobyB
                        • 5268
                        1 no
                        2 yes. Because the feed hose from the LP pump can't handle 50 psi. You need to run
                        HP fuel line from the in- tank pump to the car's hard lines. It's about 4 feet.
                        How? You get to figure that out. Anything from HP rubber OEM hose to steel hardline
                        to AN stuff.
                        t
                        • Davidov
                          • 78
                          Thanks Toby.
