m20 2.7i no power after 5k rpms cutting out
  • e3027sedan
    • 142
    i have a built 2.7i that has 2k miles on the build and recently while driving it its been cutting power at 5k rpms like as if i almost turned off the ignition it has never done this before its been smelling like alot of gas lately so seems like its running rich but idk why it would do this out of no where....any help or input would be great sorry still a newb with bmws
  • acolella76
    • 2950
    Could possibly be that it's not getting spark if it smells like fuel. Check your tune, check your coil, plugs, etc.
    -Alex
    • e3027sedan
      • 142
      ok thanks what im thinking maybe bad distributor but idk :(
      • moatilliatta
        • 6152
        Crank position sensor, and front toothed wheel mounted ok?
        @Zakspeed_US
        • e3027sedan
          • 142
          yes mounted fine that was first on my list im stumped :(
          • moatilliatta
            • 6152
            hows the sensor? try swapping it?
            @Zakspeed_US
            • Myster-E
              Performance
              • 552
              It might be a good idea to check your fuel lines and make sure they aren't leaking.
              1988 E30 335i - 1987 E30 327i - 1987 E30 327iS Pickup - 1973 2002 Project
              Visit www.BimmerHeads.com for all of your 12 valve needs!
              • BergerNJ
                • Oct 2009
                • 349
                without knowing your fuel pressure up top you wont know if its fuel.....
                  • 37833
                  Do you have all i components? Injectors, AFM, FPR, ECU, harness, plug wires, crank sensor, etc?
                  Grover Beach, California
                  BimmerHeads.com
                  • e3027sedan
                    • 142
                    yes all i components now its even worse barely runs i swapped out the maf and still nothing cuts out bad went through a half tank of gas in two days driving 50 miles dies alot at a stoplight idk im lost need help bump
                    • e3027sedan
                      • 142
                      spark plugs and wires? bump
                      • Mr. Burns
                        • Aug 2011
                        • 3516
                        didnt read all other replies, but if nobody mentioned it yet. check your crank position sensor.
                        Originally posted by flyboyx
                        i have watched my dog lick himself off a few times
                        • moatilliatta
                          • 6152
                          Does it back fire threw the intake? Get that fuel pressure reading?
                          @Zakspeed_US
                          • e3027sedan
                            • 142
                            not sure if its through the intake but what would a bad cps make it do
                            • e3027sedan
                              • 142
                              still need help bump
