'87 iS WTF am i doing wrong
  • B-well
    • 1042
  • paperplane94
    • Jul 2011
    • 420
    possible bent valve or other unrelated issue.
    Needs more info, otherwise tis a shot in the dark.
    • B-well
      • 1042
      Are these the sheet metal pullys that fail on early model m20s?
      • TobyB
        • 5243
        1 tooth probably didn't bend a valve, but a quick leakdown test would be worth it.
        I'd look at the airbox and its connections next, just on the random list....
        t
        • B-well
          • 1042
          t
          It idles fine now that the marks are lined up and only makes the horrible noise in throttle. Only touch the gas nothing wreck less.
          Nothing to do with the air box. It's loud noises like piston to valve.
          What are the chances that the timing gears themselves are tweaked or mis marked? Maybe the key or dowel is/are messed up
          • Kershaw
            • 11822
            small. but you never know.
            1 tooth off will not harm anything. the motor may have been 3 or 4 teeth off and they fixed it to 1 and sold the car.
            AWD > RWD
            • CarsSuck
              • Oct 2005
              • 968
              What kind of person rebuilds a motor and leaves a broken rotor sprocket?
              Have you pulled the valve cover and checked the valve clearance?
              Sorry I can't be of help, but when did you buy the car?
              --Will
              • E30ruben
                • Jul 2011
                • 448
                Pull the valve cover off.. You most likely have a broken rocker
                "Do what you love, and love what you do" -Ray Bradbury
                • B-well
                  • 1042
                  valve clearances are good
                  bought the car friday
                  rebuild motor with all recepits but kid couldnt get it to start
                  all new in box suspension components (billy sports and ie3 springs, front control arms, tie rods, sway links, rack bushings, trailing, sway and subframe bushings)
                  all new rotors and pads
                  all new wheel bearings
                  poly motor and diff mounts
                  new guibo
                  new clutch fw and pp
                  SS brake lines
                  3 DMEs
                  3 coils
                  2 sets of plugs
                  3 sets of injectors
                  2 AFMs
                  2 CPS's
                  2 caps and rotors
                  extra timing belt
                  extra PERFECT dash
                  konig 17s with new tires
                  all for $1k.
                  Spoiled rich kid couldnt figure out the no spark issue and had a hissy fit and sold it for pennys. i happen to see it and have my trailer hooked up and i bought it 30 minutes after he listed it on craigs
                  nope. all fresh rockers
                  my conclusion is that the head was milled and block decked thus the piston to valve clearance is to small. I'm purchasing the +0.3mm (2.05mm) head gasket and new head bolts today. will update when i install them.
                  A buddy of mine that races SE30 told me about the gasket and that he had to use it after rebuilding the motor several times. his problematic sound was similar to mine.
                    I would say that one or both of the head locating dowels are missing or that the head was over milled and valves are kissing pistons. But either of those conditions would make noise at idle. I have a suspicion that something more serious went wrong in the rebuild.
                    Do the receipts show the rebuild as being done by a shop, or are they only for parts?
                    • B-well
                      • 1042
                      rebuild was done at a very well known shop in my area that has done rebuilds for myself.
                      it does make a very faint noise at idle but much much worse in revs.
                      im going to purchase the 2.05mm gasket and see if thats all it needs. otherwise it may be time for a head that hasnt been milled
                      • Garageaholic
                        Freestyle Fabricator
                        • Dec 2005
                        • 5204
                        Looks like its time to do an m30 swap. See sig
                        Recent Rebranding!!
                        E30 SM62/S62
                        E30 M60 V8
                        E30 M30 Big 6!
                        Instagram.com/garageaholic
                        Youtube.com/garageaholic
                        • B-well
                          • 1042
                          Lol no thanks. Motor has less than 1minute total run time on a full rebuild.
                            In that case I'd take the car back to them and have them sort it out.
                            You have to take an awful lot of the head to have the valves kiss the pistons if the cam is properly timed. The are cast in pockets in the head that are the machining limit. As long as any of those pockets are still visible the valves won't get too close to the pistons.
                            I routinely mill a race head down to the limit to gain a bit of compression ratio. That does affect cam timing and that error gets corrected by an offset bushing installed into the cam sprocket.
                            • TS87325IS
                              • Sep 2006
                              • 821
                              You might want to pull the harmonic balancer off and check the timing belt alignment on the sprocket itself instead of the balancer, I have seen some with the alignment pin sheered off. Worth a look before you pull the head. If it is lined up, I would pull the head and find all the bent valves ( normally exhaust ) and replace them. ;-)
                              mods: just meat and potatoes under the hood and wheaties on fire out back ;)
